The EW-7438RPn Air is an ultra-compact Wi-Fi extender with a powerful CPU. A sleek, easy to use solution to eliminate Wi-Fi dead zones and extend wireless coverage, the EW-7438RPn Air provides practical functionality, extensive features and an elegant design.
The high-speed CPU boosts wireless performance and the guest network feature offers added value as an extra wireless network you can use for kids or guests, keeping your private Wi-Fi secure or allowing you to supervise kids' Internet use from your smartphone.
Good night mode and Wi-Fi scheduling give complete control over your wireless environment and the tiny design won't block neighboring power sockets, while 802.11 b/g/n support ensures wide compatibility and fast wireless speeds up to 300 Mbps.
Compact, Slim Wall Plug Design
Plugs directly into an existing electrical socket with no need any additional power cables. Install it anywhere you need.
Setup Is Easy
Features user-friendly browser-based iQ Setup for smart, automatic and quick installation. iQ Setup automatically detects available Wi-Fi networks and helps you to establish a connection within seconds.
Smart App Control & Analytics
The extender works together with our free EdiRange smartphone app which displays your local Wi-Fi environment and provides easy-to-understand analytics to help you avoid your neighbors’ wireless interference and get the best performance for your wireless devices. Plus you can manage the extender’s wireless network and functions such as scheduling and guest network.
Good Night Mode & Wi-Fi Scheduling
The extender’s free smartphone app lets you shut down the extender’s Wi-Fi from your smart phone, so when you go to bed, you can put your extender to sleep too. Just hit "good night mode" in the app and see that the extender’s Wi-Fi and LEDs are off during the night, leaving you or your family ready for a comfortable night’s sleep. And the additional Wi-Fi scheduling function lets you program intelligent schedules to manage Wi-Fi availability and power usage according to your home’s routine.
Parental Control or Guest Wi-Fi
The EW-7438RPn Air features a 2nd wireless network which is easy to set up and manage using the included smartphone app. It could be used for guests to keep your home Wi-Fi private and secure, or for children as a parental control function. Separate your child’s Wi-Fi network from yours so you can switch it on or off at anytime and have total control with the smartphone app. Use the extender’s scheduling function to regulate the times which children can get online or switch off the extender so there’s no distractions when kids are doing homework.
New Generation, Better Performance, Reduced Size
The EW-7438RPn Air features an embedded 580MHz CPU which enhances Wi-Fi performance by up to 45% and is equipped with two internal high performance antennas.
Eliminate Wi-Fi Dead Zones
Extend Wi-Fi coverage to dead zones which your existing Wi-Fi signal can’t reach.
Double The Coverage Of Your Wi-Fi
Plug the extender directly into an electrical outlet and the extender can double the signal coverage of your Wi-Fi network, perfect for large homes with multiple rooms and floors.
Works With Any Wireless Router
Universal compatibility and easy web-based iQ Setup for quick and easy installation.
Quick WPS Connection
A WPS (Wi-Fi Protected Setup) button allows the EW-7438RPn Air to join an existing wireless network at the simple push of a button.
WPA/WPA2 Advanced Wireless Encryption
Supports WEP 64/128 bit, WPA and WPA2 wireless encryption standards.
*Maximum performance, actual data rates, and coverage will vary depending on network conditions and environmental factors.
*Actual viewing resolution and frame rate of network cameras depend on connection speed.
*Product specifications and design are subject to change without notice.
Compact, slim wall plug design
Plugs directly into an existing electrical socket with no need any additional power cables. Install it anywhere you need. -
Setup is easy
Features user-friendly browser-based iQ setup for smart, automatic and quick installation. iQ setup automatically detects available Wi-Fi networks and helps you to establish a connection within seconds. -
The extender's free smartphone app lets you shut down the extender's Wi-Fi from your smart phone, so when you go to bed, you can put your extender to sleep too. Just hit "good night mode" in the app and see that the extender's Wi-Fi and LEDs are off during the night, leaving you or your family ready for a comfortable night's sleep. -
Parental control or guest Wi-Fi
The EW-7438RPn Air features a 2nd wireless network which is easy to set up and manage. It could be used for guests to keep your home Wi-Fi private and secure, or for children as a parental control function. Separate your child's Wi-Fi network from yours so you can switch it on or off at anytime and have total control with the smartphone app. -
Better performance, reduced size
The EW-7438RPn Air features an embedded 580 MHz CPU which enhances Wi-Fi performance by up to 45% and is equipped with two internal high performance antennas. -
Eliminate Wi-Fi dead zones
Extend Wi-Fi coverage to dead zones which your existing Wi-Fi signal can't reach. -
Double the coverage of your Wi-Fi
Plug the extender directly into an electrical outlet and the extender can double the signal coverage of your Wi-Fi network, perfect for large homes with multiple rooms and floors. -
Works with any wireless router
Universal compatibility and easy web-based iQsetup for quick and easy installation. -
Quick WPS connection
A WPS (Wi-Fi Protected Setup) button allows the EW-7438RPn Air to join an existing wireless network at the simple push of a button. -
WPA/WPA2 advanced wireless encryption
Supports WEP 64-/128-bit, WPA and WPA2 wireless encryption standards.
- Edimax EW-7438RPn Air - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power
- AC 120/230 V (50/60 Hz)
- 4.2 cm x 7.2 cm x 4.2 cm
- 49 g
- 4.2 cm
- 7.2 cm
- 4.2 cm
- 49 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Status
- Parental control, firmware upgradable, Wi-Fi Protected Setup (WPS), 802.1x authentication
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.1x
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- FCC
- Power Device
- Internal power supply
- Voltage Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
