Product
Edimax Fast Ethernet 8 Port Smart Managed Switch
Quicklinx: BYRQWS00 Mfr#: ES-5208P
The Edimax ES-5208P is a web-smart switch with 8 fast Ethernet PoE+ ports and 2 Gigabit combo ports. It easily connects and supplies power to PoE-enabled devices such as wireless access points, network cameras and IP phones as well as other Ethernet-enabled devices such as computers, printers and network attached storage (NAS). ES-5208P is designed with easy management, all configuration can be performed through an intuitive browser-based Graphical User Interface. Ideal for small or medium network environments to strengthen the network connection, its standard rack-mount brackets allow for integration with the most widely used mounting systems on the market.
  • Cost-effective, no special networking cable required
    Reduce your installation time and cost by using a standard Cat-5e Ethernet cable to link between the ES-5208P switch and powered devices (PD). The Ethernet cable will then transmit both data and power, so you won't need all those extra power cables to your powered devices (PD).
  • Smart features supported
    The ES-5208P web smart features can be managed through a Web Browser. The smart features include simple QoS/CoS applications and basic monitoring tools to improve network efficiency. The ES-5208P also supports bandwidth control and port based VLAN. Through a Web interface, an administrator can set up VLANs to segregate traffic and QoS to prioritize mission-critical data. All of these features offer extra protection on the network edge. Best of all, the password-protected configuration interface can be accessed remotely. It increases the IT manager's mobility.
  • High performance
    The ES-5208P switch also supports auto-negotiation and non-blocking wire speed to give you the maximum speed and highest performance possible for each device connected to your network.
Edimax ES-5208P - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - smart
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
130 W
Performance
Switching capacity: 2.8 Gbps
MAC Address Table Size
4K entries
Jumbo Frame Support
1536 bytes
Remote Management Protocol
HTTP
Flow control, full duplex capability, auto-negotiation, IGMP snooping, packet filtering, port mirroring, store and forward, Broadcast Storm Control, Quality of Service (QoS), reset button, bandwidth control, 352KB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3at
33 cm x 23 cm x 4.4 cm
2.3 kg
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
130 W
Performance
4K entries
Jumbo Frame Support
1536 bytes
HTTP
Status Indicators
Power, system, PoE, link/activity
24 x 100Base-TX RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 , 2 x SFP
Internal power supply
390 Watt
Rack Mounting Kit
Included
FCC
33 cm
23 cm
4.4 cm
2.3 kg
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
