Edimax EW-7228APn Wireless N 150 Range Extender 5 Port Sw
Quicklinx: 7BJQWS00 Mfr#: EW-7228APN
Type: Radio access point
Connectivity: Wireless
Speed: 150Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
4 on order, delivery delayed
£15.78 ex VAT
£18.93 inc VAT
Wireless 802.11n Range Extender/Access Point
Acting as a bridge between the wired Ethernet and the 2.4GHz IEEE 802.11b/g/n wireless LAN, this wireless LAN Range Extender/Access Point can let your wireless LAN client stations access both the wired and the wireless network nodes.
Universal Repeater Mode
The Universal Repeater Mode lets this Range Extender/Access Point extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schools...etc.
Robust Wireless LAN Security (WPA, WPA2 support)
Except for the basic security control by using ESSID and 64/128 bit key length WEP encryption, the EW-7228APn also supports the advanced security features, like MAC access control, IEEE 802.1x authentication, TKIP, AES and hide ESSID. It provides a total solution for you building up a secure wireless LAN network environment that can prevent from all kinds of hacker intrusion.
Multi-languages Setup Wizard
An unique Multi-languages Setup Wizard is provided in the bundled CD. You only need to make sure the access point is properly connected to the network without specifying your PC's IP address before starting the configuration. The EZmax Wizard will detect your Range Extender/Access Point automatically and guide you to follow a few simple steps to complete the settings within minutes.
Web Configuration
The EW-7228APn allows you to configure this Range Extender/Access Point through the friendly Web user interface with a browser.
Support Green WLAN
The EW-7228APn has adapted a clever protocol in smart transmission power control. When the wireless is idle, the Range Extender/Access Point smartly adjusts transmission output by distance and CPU offload to reduce power consumption 26%~39% comparing the power consumption under data is transmitted.
*The result may be varied in different networking environment
  • Wireless 802.11n range extender/access point
    Acting as a bridge between the wired Ethernet and the 2.4GHz IEEE 802.11b/g/n wireless LAN, this wireless LAN range extender/access point can let your wireless LAN client stations access both the wired and the wireless network nodes.
  • Universal repeater mode
    The universal repeater mode lets this range extender/access point extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schools... etc.
  • Robust wireless LAN security (WPA, WPA2 support)
    Except for the basic security control by using ESSID and 64/128 bits key length WEP encryption, the EW-7228APn also supports the advanced security features, like MAC access control, IEEE 802.1x authentication, TKIP, AES and hide ESSID. It provides a total solution for you building up a secure wireless LAN network environment that can prevent from all kinds of hacker intrusion.
  • Web configuration
    The EW-7228APn allows you to configure this range extender/access point through the friendly web user interface with a browser.
  • Support Green WLAN
    The EW-7228APn has adapted a clever protocol in smart transmission power control. When the wireless is idle, the range extender/access point smartly adjusts transmission output by distance and CPU offload to reduce power consumption 26%-39% comparing the power consumption under data is transmitted.
Edimax EW-7228APn - radio access point
Radio access point
External
RAM
16 MB
Flash Memory
2 MB
Ports Qty
5
Frequency Band
2.4 GHz
13.6 cm x 9 cm x 2.6 cm
Radio access point
13.6 cm
9 cm
2.6 cm
Processor / Memory / Storage
RAM
16 MB SDRAM
Flash Memory
2 MB
External
Ports Qty
5
Wireless
Data Transfer Rate
150 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
DSSS
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz
Status Indicators
Power, WLAN, LAN
DHCP support, repeating mode, auto-fallback, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Trivial File Transfer Protocol (TFTP) support, Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, hidden SSID, wireless bridge mode, Green WLAN
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Authentication Method
RADIUS, Extended Service Set ID (ESSID), Basic Service Set Identifier (BSSID)
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
1
Gain Level
3 dBi
5 x 100Base-TX - RJ-45
FCC, RoHS
External power adapter
Software Included
Drivers & Utilities
10 - 90% (non-condensing)
Speed: 150Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Edimax
Price Range Ex VAT: 0 - 50
