Edimax BR-6208AC Wi-Fi Ethernet LAN Dual-band Router - Grey
Quicklinx: 9TH6WS00 Mfr#: BR-6208AC
  • IEEE 802.11n
Edimax BR-6478AC AC750 Multi-Function Concurrent Dual-Band Wi-Fi Router
AC750 WiFi Concurrent Dual-band Router, 3*High Gain Antennas for Better Range, Easy Install as Router /AP/Range Extender/Wi-Fi Bridge/WISP Multi-mode
The extraordinary growth in the number of wireless devices found in modern homes has seen a huge increase in demand for wireless speed, range and bandwidth. This continuing trend away from wired connections to wireless communication and the ever-increasing throughput demands of new Wi-Fi devices and applications--including Internet TVs, computers, tablets and smartphones--drives the requirements in today's homes for high-performance, reliable Wi-Fi to unprecedented levels. To meet the connectivity needs of homes and businesses alike, Edimax has launched the BR-6208AC dual-band 802.11ac router: featuring the latest 11ac standard for extraordinary improvements in the speed, reliability and quality of wireless communications.
Next-Generation Wireless Networking
The Edimax BR-6208AC router supports the next generation IEEE 802.11ac wireless standard, meaning higher data rates in the 5GHz band. With 300Mbps speeds in the 2.4GHz band and 433Mbps speeds in 5GHz, the BR-6208AC is ideal for HD video streaming and large file transfers. The router is also backward compatible with 802.11a/b/g/n to ensure compatibility with legacy Wi-Fi devices.
Concurrent Dual-Band Wi-Fi Connectivity
The Edimax BR-6208AC router provides simultaneous 2.4GHz (802.11n) and 5GHz (802.11ac) wireless network connectivity for maximum flexibility of use.
Three Antennas For Better Wi-Fi Performance
Employing three external fixed antennas,the BR-6208AC provides powerful 2.4GHz and 5GHz dual-band signal strength and enhances Wi-Fi range, providing signal penetration through walls and floors across your home or office.
5-in-1 Router, Access Point, Range Extender, Wireless Bridge and WISP
The BR-6208AC can work as router, access point, range extender, wireless bridge or WISP. Just configure the mode you need for your network environment using the smart iQ Setup wizard.
Switch mode using the smart iQ setup wizard on any device with a web browser, no CD required.
*Mobile device setup requires iOS 4.0 or Android 4.0 and above.
Smart iQ Setup
Features iQ Setup for smart, automatic and quick installation with no CD required.
Edimax's Revolutionary iQoS
iQoS is Edimax's solution for a quicker, easier, and more effective way to manage Internet bandwidth. While Quality of Service (QoS) functionality is a common feature in routers across the market, typically only advanced users have the knowledge required to set up the complex parameters. Edimax though has redesigned QoS with user-friendliness and accessibility in mind. A simple and intuitive user interface allows users to arrange bandwidth priority settings in just a few clicks. With iQoS, you can enjoy gaming, video streaming, VoIP applications and BT clients at the same time without the usual nightmare of lag and interruptions. An original, efficient and effective means of managing your Internet bandwidth.
Multi-SSID & VLAN Support*
?Multi-SSID enables users to configure up to eight separate SSIDs (2.4GHz x 4 and 5GHz x 4) in order to group and manage users according to your requirements. In addition, each SSID can be assigned a different VLAN ID, so users with multiple VLANs can manage the network access level of each SSID - ensuring security and protecting confidential or critical network resources.
*Access point mode only
Guest Network*
Supports a guest network to provide connectivity while isolating guests from your primary network.
*Router mode only
Next generation 802.11ac Wi-Fi standard
Backward compatible with 802.11a/b/g/n standards
Concurrent dual-band wireless connectivity for 2.4GHz and 5GHz
High gain fixed antennas for better Wi-Fi performance
Supports up to 8 Multi-SSID (2.4GHz x 4 and 5GHz x 4) & VLAN (AP mode only)
Supports guest network (router mode only)
Revolutionary iQoS for efficient and effective internet bandwidth management
  • 5-in-1 router, access point, range extender, wireless bridge, and WISP
    The BR-6208AC can work as router, access point, range extender, wireless bridge, and WISP. Just configure the mode you need for your network environment using the smart iQ setup wizard.
  • Concurrent dual-band Wi-Fi connectivity
    The Edimax BR-6208AC router provides simultaneous 2.4 GHz (802.11n) and 5 GHz (802.11 ac) wireless network connectivity for maximum flexibility of use.
  • 5 dBi high gain antennas for better Wi-Fi performance
    Employing three external 5 dBi high-gain fixed antennas, the BR-6208AC provides powerful 2.4 GHz and 5 GHz dual-band signal strength and enhances Wi-Fi range, providing signal penetration through walls and floors across your home or office.
Edimax BR-6208AC - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DDNS
Routing Protocol
Static IP routing
DMZ port, IGMP snooping, DoS attack prevention, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), port triggering, Stateful Packet Inspection Firewall (SPIF), IGMP proxy
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
433 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, FCC
Status Indicators
Power, WAN, LAN, wireless, link/activity
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
Antenna Qty
3
Gain Level
5 dBi
External power adapter
Software Included
Drivers & Utilities
