The Edimax EW-7822UAC is the Wi-Fi adapter, compatible with the draft 802.11ac standard. The EW-7822AC is the adapter of its kind to offer 802.11ac speeds together with USB 3.0 connectivity.
The EW-7822UAC's sleek design features an adjustable foldaway antenna, allowing users to adjust the antenna's angle for optimum Wi-Fi performance and fold back the antenna to minimize size when it's not in use.
802.11ac truly realized with USB 3.0
USB 3.0 is up to 10 times faster than USB 2.0 and specifies a maximum transmission speed of up to 5 Gbps. Providing quicker data transmission times, and backwards compatibility with USB 2.0, USB 3.0 is the standard in connectivity - enabling devices to achieve the superfast speeds which 802.11ac can provide. -
Fast USB Wi-Fi adapter
The Edimax EW-7822UAC is the Wi-Fi adapter, compatible with the draft 802.11ac standard. The EW-7822AC is the adapter of its kind to offer 802.11ac speeds together with USB 3.0 connectivity. -
Download and stream anywhere
Use the EW-7822UAC to download and stream media from YouTube, Netflix or other services without waiting for buffering, or stream media across your network from a NAS (network-attached storage) at lightning speeds. Streaming HD movies or downloading is faster and more reliable than ever with 802.11ac Wi-Fi. -
Adjustable foldaway antenna
The EW-7822UAC's sleek design features an adjustable foldaway antenna, allowing users to adjust the antenna's angle for optimum Wi-Fi performance and fold back the antenna to minimize size when it’s not in use.
- Edimax EW-7822UAC - network adapter - USB 3.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- 2.7 cm x 8.71 cm x 1.8 cm
- 23 g
- Data Link Protocol
- 802.11a, 802.11b/g/n, Wi-Fi 5
- Data Transfer Rate
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, USB 3.0, Wi-Fi Protected Setup, IEEE 802.11ac (draft)
- System Requirements
- Microsoft Windows Vista / XP / 7, Windows 8
- Network adapter
- Form Factor
- External
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- External integrated and internal
- Antenna Qty
- 2
- Connections
- 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- PCT, FCC Part 15 B, R&TTE, RoHS, WEEE
- Software Included
- Drivers & Utilities, EZmax Setup Wizard
- OS Required
- 2.7 cm
- 8.71 cm
- 1.8 cm
- 23 g
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
