Product
Edimax 850nm MMF Gb LAN/FC Adaptor
Quicklinx: 763SWS00 Mfr#: MG-1000AMA
  • Compliant with IEEE 802.3z Gigabit Ethernet, and Fiber Channel standard
  • Compatible module to AGM731F
  • Industry standard SFP package
  • Single 3.3V power supply
  • Simplex/ Duplex LC connector
  • Up to 1.25Gb/s bi-directional data links
  • Die cast metal housing for Low EMI
  • Hot Pluggable
  • Class 1 laser product complies with EN 60825-1
Edimax MG-1000AMA - GBIC transceiver module - GigE, Fibre Channel
GBIC transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
GigE, Fibre Channel
Max Transfer Distance
550 m
Plug-in module
Wired
Cabling Type
1000Base-SX
GigE, Fibre Channel
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode
Compatible Slots
1 x SFP (mini-GBIC)
FCC, RoHS, Laser Class 1, IEC 60825-1
