Edimax 300Mbps Wireless PCI-E Adapter V2
Quicklinx: 98ZMWS00 Mfr#: EW-7612PIN V2
Wired / Wireless: Wireless
Protocol: IEEE 802.11g, IEEE 802.11n, IEEE 802.11b
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
Hurry, only 2 left in stock!
£12.60 ex VAT
£15.12 inc VAT
Express delivery Order within the next 21 hours for delivery on Monday
The Edimax EW-7612PIn V2 N300 Wireless PCI Express Adapter is an easy way to add Wi-Fi connectivity to your desktop computer. Built with the 802.11n standard, 2T2R MIMO technology, and two high-gain 3 dBi detachable antennas, this wireless PCIe adapter allows for fast and stable wireless networking with data speeds of up to 300Mbps. It can be easily set up with the bundled EZmax multi-language setup wizard, and it comes with a low-profile bracket for installation on small computers.
  • Wireless 802.11n standard
    The Edimax EW-7612PIn V2 allows for increased wireless coverage and higher data transmission rates. The latest wireless technology is built into this device to broaden its wireless coverage by 5 times and to reduce dead spots within the wireless range. The EW-7612PIn V2 complies with wireless IEEE 802.11b/g/n standards and can reach data transmission rates of up to 300 Mbps when connected to wireless 802.11n devices. It also extends its wireless signal distance, and provides more reliable wireless connections than standard IEEE 802.11b/g wireless networks.
  • First-class reliability
    The EW-7612PIn V2's exceptional chipset offers increased bandwidth and more functionality than other PCI network adapters. This adapter is specifically designed to utilize the full bandwidth capacity of the PCI Express bus, thus eliminating collisions and latencies that exist with current 32-bit and 64-bit PCI bus architectures.
  • Wi-Fi protected setup (WPS) button
    The Edimax EW-7612PIn V2 features a convenient WPS button. Users can set up an encrypted wireless connection simply by pressing the WPS button on this adapter and a WPS-enabled wireless access point. This one-click WPS button helps users set up a secure wireless network in less than a minute.
  • High-gain 3 dBi detachable antennas for improved wireless performance
    The EW-7612PIn V2 comes with two high-gain 3 dBi detachable antennas, which enable it to achieve better signal quality compared to common wireless adapters. The antennas' detachable design also gives users the flexibility of using the antennas with extension cables for optimal antenna placement.
Edimax EW-7612PIn V2 - network adapter - PCIe
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
12.1 cm x 8.8 cm x 2.2 cm
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup
Microsoft Windows Vista / XP / 7 / 8
Network adapter
Plug-in card
PCI Express
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Transmit, receive, link/activity
Wi-Fi Protected Setup (WPS), 802.1x authentication
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
3 dBi
2 x aerial - RP-SMA
Low-profile bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC
Software Included
EZmax Setup Wizard
12.1 cm
8.8 cm
2.2 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Compatibility: PC
Brand: Edimax
Stock Status: In stock
