Edimax 1.3Mpx Wireless Network Camera
Quicklinx: 98GYWS00 Mfr#: IC-3115W
The Edimax IC-3115W is a highly cost-effective network camera designed for easy home monitoring. About the size of an average smartphone, the Edimax IC-3115W can be easily set up on a table or on the wall, so you can always keep an eye on the safety of your pets, property, or loved ones. The Edimax IC-3115W comes in a glossy white finish and a simplistic design, allowing it to blend in perfectly with your home decoration. The Edimax IC-3115W 1.3Mpx Wireless Network Camera is simply the best choice for easy home monitoring.
Edimax Plug-n-View
Edimax Plug-n-View technology makes it easy for you to keep an eye on the safety of your home, family, pets, and assets wherever you go. With Plug-n-View technology, you can set up your Edimax network camera in a few simple steps. The camera also connects to the cloud automatically, so you can access it remotely with a smartphone, tablet, or computer no matter where you are.
Wide Angle, High Quality Videos
The Edimax IC-3115W is built with a wide 1.7mm (28mm equiv.) lens that covers a viewing angle of 74.8 degrees, making it suitable for capturing video footage of a wide area with a single network camera. With a 1.3 megapixel CMOS sensor, this network camera is able to capture SXVGA (1280 x 960) videos at 30 frames per second.
Motion-Triggered Snapshots
The IC-3115W is designed with a powerful multi-area motion detection system. When motion is detected in the specified areas, the network camera will immediately take a snapshot of the detected motion and send the snapshot to the user via email or FTP.
Free Management Software for PC, iPhone, and Android Phones
The Edimax IC-3115W comes with a free 16-channel viewer software for PC that allows users to access and manage up to 16 network cameras simultaneously. This viewer software supports manual, cycle, and scheduled video recording for every surveillance application. Additionally, the IC-3115W network camera's free EdiView viewer app for iPhone and Android phones allows users to access the network camera without a computer at all.
3-level user access (administrator/operator/guest)
Multi-area motion detection
Sends motion-detected snapshots to email and FTP
Recording upon detected motion
SXVGA (1280 x 960) resolution at 30fps
WPS support for easy connection
Viewer software to access 16 network cameras simultaneously
Manually and cycle recording
Up to 16 login accounts
Free EdiView viewer app for iPhone & Android phones
  • Edimax Plug-n-View
  • Wide angle, high quality videos
    The Edimax IC-3115W is built with a wide lens that covers a viewing angle of 74.8 degrees, making it suitable for capturing video footage of a wide area with a single network camera. With a 1.3-megapixel CMOS sensor, this network camera is able to capture SXVGA (1280 x 960) videos at 30 frames per second.
  • Motion-triggered snapshots and recording
    The IC-3115W is designed with a powerful multi-area motion detection system. When motion is detected in the specified areas, the network camera will immediately take a snapshot of the detected motion and send the snapshot to the user via email or FTP. The multi-area motion detection function also works with the network camera's recording feature. When motion is detected, the IC-3115W is able to produce video footage of the monitored area up to 60 seconds in length.
Edimax IC-3115W - network surveillance camera
Network surveillance camera - fixed
6.5 cm x 2.7 cm x 8 cm
Wired, wireless
Camera
Frame Rate (max)
Motion Detection
Optical Sensor Type
CMOS 1.3 MP
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 5 V
Motion Detection Technology, upgradable firmware, Wi-Fi Protected Setup (WPS)
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Wired, wireless
6.5 cm
2.7 cm
8 cm
Camera
Colour - fixed
Digital Video Format
AVI, MJPEG
Motion Detection
Video Capture
1280 x 960 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
Supported Image Formats
JPEG
Still Image Capture Resolution
640 x 480, 1280 x 960, 320 x 240
RAM
32 MB
Flash Memory
4 MB
Image Sensor
1.3 MP CMOS
Lens Construction
Horizontal Field of View (degree)
74.8
Vertical Field of View (degree)
74.8
Network Interface
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Mounting kit, Cloud ID card
1 x network cable - external
FCC
Power Requirements
DC 5 V
Power adapter - external
Software Included
EdiView Finder
Relative Humidity (operating)
