The Edimax IC-3116W 720p wireless network camera is a versatile monitoring device ideal for monitoring your home, shop or factory during the daytime or at night. With Edimax Plug-n-View technology, no complicated setup is required and you can easily connect the camera to the cloud and monitor remotely from a smartphone, tablet or laptop. Motion-triggered snapshots and recording to email ensure that you capture every criminal event. The IC-3116W comes with a wireless interface making installation easy for any home/store/factory monitoring applications.
Plug-n-View for 24/7 Easy Remote Monitoring
Edimax Plug-n-View technology makes it easy for you to keep your yard, garage, shop, factory or other assets wherever you go. With Plug-n-View technology, you can connect your network camera to the cloud in a few simple steps and access it remotely with a smartphone, tablet, or computer no matter where you are.
Night Vision
With a light sensor, image sensor, and IR LEDs, the IC-3116W can satisfy all security and indoor surveillance needs even in dimly lit environments. And with automatic ICR (IR Cut Filter Removal), infrared light is filtered out during the day time and allowed to pass during the night time, ensuring video color quality in comparison with other IP cameras.
Motion-Triggered Snapshots & Recording
The powerful motion detection system built into this network camera ensures that you have evidence of a criminal event. You can pre-define an area in the monitored range for motion detection; and when motion is detected in the specified area, the network camera will produce snapshots or video footage of the event immediately.
High Quality VideosThe Edimax IC-3116W is built with a wide 2.2mm lens that covers a diagonal viewing angle of 69 degrees, making it suitable for capturing video footage of a wide area with a single network camera. With a megapixel CMOS sensor, this network camera is able to capture 720p (1280 x 720) videos at 24 frames per second.
SOFTWARE FEATURES
Easy remote monitoring via iPhone, iPad, Android, PC & Mac
High-speed H.264 & MJPEG video compression
Motion detection
Sends motion-detected snapshots to email and FTP
Pre- & post-recording upon detected motion
Viewer software to access 16 network cameras simultaneously
Manual/scheduled/cycle recording
Plug-n-View for 24/7 easy remote monitoring
Edimax Plug-n-View technology makes it easy for you to keep your yard, garage, shop, factory or other assets wherever you go. With Plug-n-View technology, you can connect your network camera to the cloud in a few simple steps and access it remotely with a smartphone, tablet, or computer no matter where you are. -
Night vision
With a light sensor, image sensor, and IR LEDs, the IC-3116W can satisfy all security and indoor surveillance needs even in dimly lit environments. And with automatic ICR (IR Cut Filter Removal), infrared light is filtered out during the day time and allowed to pass during the night time, ensuring video color quality in comparison with other IP cameras. -
Motion-triggered snapshots & recording
The powerful motion detection system built into this network camera ensures that you have evidence of a criminal event. You can pre-define an area in the monitored range for motion detection; and when motion is detected in the specified area, the network camera will produce snapshots or video footage of the event immediately. -
High quality videos
The Edimax IC-3116W is built with a wide 2.2 mm lens that covers a diagonal viewing angle of 69 degrees, making it suitable for capturing video footage of a wide area with a single network camera. With a megapixel CMOS sensor, this network camera is able to capture 720p videos at 24 frames per second.
- Edimax IC-3116W - network surveillance camera
- Network surveillance camera - fixed
- 6.5 cm x 2.72 cm x 11 cm
- 100 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS 1.3 MP
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external
- Voltage
- DC 12 V
- Motion Detection Technology, infrared cut filter, upgradable firmware, Wi-Fi Protected Setup (WPS)
- Environmental Parameters (operating)
- 0 °C - 60 °C; 20 - 80% (non-condensing) relative humidity
- Wired, wireless
- 6.5 cm
- 2.72 cm
- 11 cm
- 100 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- AVI, MJPEG
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Capture
- 1280 x 720 @ 24 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
- Supported Image Formats
- JPEG
- Still Image Capture Resolution
- 1280 x 720, 640 x 480, 320 x 240
- RAM
- 64 MB
- Flash Memory
- 8 MB
Image Sensor
- 1.3 MP CMOS
- Network Interface
- Network Protocols
- DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, IPv4, RTCP, PPPoE
- Interfaces Details
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Mounting kit
- Cables Included
- 1 x network cable - external
- FCC
- Power Requirements
- DC 12 V
- Power Device
- Power adapter - external
- Software Included
- Drivers & Utilities
- 0 °C
- 60 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
