Edge10 EdgeRouter POE 5-port
Quicklinx: CQXVWS00 Mfr#: ERPoe-5
Type: Router
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet
Speed: 1Gbps
£149.98 ex VAT
£179.97 inc VAT
EdgeRouter combines carrier-class reliability with enterprise-level features in a compact and affordable unit. The EdgeRouter PoE is the economical router capable of routing up to 1 million packets per second.
Powered by a proprietary and intuitive graphical interface, EdgeOS, EdgeRouter can easily be configured for routing, security, and management features required to efficiently run your network. For advanced network professionals, an integrated CLI is available for quick and direct access using familiar commands.
  • DHCP server
    Set up multiple DHCP servers to assign IP ranges in different subnets on the different interfaces. Easily control dynamic and static IP addressing for your network devices.
  • Monitoring tools
    Conveniently track network activity and devices from tools such as ping, trace, discover, packet capture, and log monitor.
  • User accounts
    Manage access to the EdgeRouter using unique administrator and operator accounts.
  • Firewall policies
    Organize the rules you apply in the order you specify. Firewall groups apply the policies to groups filtered by IP address, network address, or port number.
  • NAT rules
    The EdgeRouter changes packet addressing based on your customized source and destination NAT rules.
  • Interfaces
    Each Gigabit port functions as an independent interface. You can also configure virtual local area network (VLAN) interfaces for network segmentation.
  • Routing
    Configure static routes and dynamic routing protocols to effectively manage the routes used by the EdgeRouter. With these capabilities and more, the EdgeRouter provides the centralized control you need to optimize the performance and reliability of your network.
  • Intuitive user interface
    The EdgeRouter provides a graphical user interface designed for convenient setup and control. Accessed via a network port and web browser, the user-friendly interface provides intuitive management with a virtual view of the ports, displaying physical connectivity, speed, and status.
Ubiquiti EdgeRouter PoE - router - desktop, wall-mountable
Router - 5-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Data Transfer Rate
1 Gbps
Performance
Forwarding performance (64-byte packet size): 1000000 packets per second , Forwarding performance (large packets): 3 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE
Routing Protocol
OSPF, RIP, BGP, IGMP, GRE, OSPFv3, RIPng
Remote Management Protocol
SNMP, Telnet, HTTP, SSH, CLI
Flow control, firewall protection, Layer 3 switching, NAT support, VLAN support, dynamic DNS server, Virtual Route Redundancy Protocol (VRRP) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, DHCP server, static IP mode, reset button, LLDP support, DHCP relay, NetFlow, static routing, IGMP proxy
IEEE 802.1Q, IEEE 802.3ad (LACP)
20 cm x 9 cm x 3 cm
360 g
Enclosure Type
Wired
Data Transfer Rate
1 Gbps
Performance
Routing Protocol
IEEE 802.1Q, IEEE 802.3ad (LACP), IC, FCC
1 x MIPS MIPS64 500 MHz
RAM
512 MB DDR2 SDRAM
Flash Memory
2 GB
Status Indicators
Port status, power, PoE, link/activity
LAN: 5 x 10Base-T/100Base-TX/1000Base-T (PoE) - RJ-45 , Management: 1 x RJ-45
External power adapter
60 Watt
OS Provided
Ubiquiti EdgeOS
20 cm
9 cm
3 cm
360 g
-10 °C
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Speed: 1Gbps
Brand: Edge10
Price Range Ex VAT: 100 - 150
