The Eaton 9130 UPS delivers online power quality and scalable battery runtimes for servers, voice and data networks, storage systems and other IT equipment. With an efficiency rating of 95% in online double conversion and 98% in high efficiency mode the 9130 UPS cuts energy costs while significantly extending battery service life with ABM technology. The 9130 UPS also has a bright LCD user interface to simplify monitoring.
Double-conversion design for superior power protection
The 9130 is constantly monitoring power conditions - regulating both voltage and frequency. Even when presented with the most severe power problems, this UPS's output remains within three percent of nominal voltage. The 9130 does not depend on batteries to smooth out minor power fluctuations. Batteries are conserved for those times when utility power is highly unstable or completely out. If an outage occurs, the 9130 transfers to battery with zero interruption in power, making this an ideal UPS for sensitive and critical equipment. -
More real power for less cost
High 0.9 output power factor enables the 9130 to provide its full power capability to modern IT equipment that may have a wide range of leading and lagging power factors. With a 0.99 input power factor, this UPS avoids the disturbances that some energy converters tend to cause. The more efficient the UPS, the lower your utility and cooling bills. Even a small increase in efficiency can quickly translate into thousands of dollars. When power conditions are within acceptable limits, the 9130 can operate in a remarkably high-efficiency mode - 95 percent efficient or higher. -
Advanced design and self-monitoring for premium availability
The 9130 continually monitors voltage, temperature, internal element functions, battery health, battery state-of-charge and runtime remaining. If the UPS detects a potential problem with any of these measures, it sends alarms or takes corrective action, with no interruption in power. At the end of an alarm condition, the 9130 automatically reverts from bypass to normal operation. -
Stronger, longer battery life with exclusive ABM technology
Most UPS manufacturers on the market today employ a constant 'trickle-charging' system, which can ultimately reduce potential battery service life by as much as 50 percent. In contrast, ABM technology uses sophisticated sensing circuitry and an innovative three-stage charging technique that significantly extends UPS batteries' useful service life while optimizing their recharge time. You have ample time to hot-swap batteries without ever having to shut down connected equipment. -
External battery modules for extended runtime
During a power outage, internal batteries in the 9130 keep loads running long enough to gracefully shut down systems. Add more runtime at any time, with up to four external battery modules to run systems for hours if necessary. These battery modules are hot-swappable and can be replaced at any time without powering down the UPS or protected loads. You can also start up the UPS and power its loads with battery power.
- Eaton PW9130i700T - UPS - 630 Watt - 700 VA
- UPS - external
- 12.2 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 630 Watt / 700 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 6 x power IEC 60320 C13
- Battery
- Lead Acid - 9 Ah
- Battery Form Factor
- Internal
- Batteries Qty
- 2
- Run Time (Up To)
- 5 min at full load
- Networking
- RS-232, USB
- Included Accessories
- Cable retention brackets
- Black
- 16 cm x 35 cm x 23 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 276 V
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 630 Watt / 700 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Efficiency
- 95%+
- Quantity
- 2
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 9 Ah
- Run Time (Up To)
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x Communication slot
- Cables Included
- USB cable - external
- Advance Battery Management (ABM), audible alarm, LCD display, internal bypass, LED indicators, automatic self-test
- GS, EN 62040-2
- Software Included
- Eaton Software Suite
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
- Sound Emission
- 50 dB
- 16 cm
- 35 cm
- 23 cm
- 12.2 kg
