The Eaton 9130 UPS delivers online power quality and scalable battery runtimes for servers, voice and data networks, storage systems and other IT equipment. With an efficiency rating of 95% in online double conversion and 98% in high efficiency mode the 9130 UPS cuts energy costs while significantly extending battery service life with ABM technology. The 9130 UPS also has a bright LCD user interface to simplify monitoring.
- Eaton PW9130i1000T-XL - UPS - 900 Watt - 1000 VA
- UPS - external
- 14.5 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 900 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 6 x power IEC 60320 C13
- Battery
- Lead Acid - 9 Ah
- Battery Form Factor
- Internal
- Batteries Qty
- 3
- Run Time (Up To)
- 6 min at full load
- Networking
- RS-232, USB
- Included Accessories
- Cable retention brackets
- 16 cm x 38 cm x 23 cm
- 2 years warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 276 V
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Efficiency
- 95%+
- Quantity
- 3
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 9 Ah
- Run Time (Up To)
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x Communication slot
- Cables Included
- USB cable - external
- Advance Battery Management (ABM), audible alarm, LCD display, internal bypass, LED indicators, automatic self-test
- GS, EN 62040-2
- Software Included
- Eaton Software Suite
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
- Sound Emission
- 50 dB
- 16 cm
- 38 cm
- 23 cm
- 14.5 kg
