The 2U Extended Battery Module (EBM) gives additional runtime to the Eaton 5130 1250 and 1750 UPSs. Up to 4 EBMs can be attached to each UPS in order to extend the run time to several hours.
- Eaton 5130 EBM 3000 RT 2U - battery enclosure
- Battery enclosure - rack-mountable / external
- Rack Size
- 2U
- 41.7 kg
- Run Time (Up To)
- 17 min
- 44.1 cm x 63.4 cm x 8.6 cm
- Height (Rack Units)
- 2U
- Run Time (Up To)
- 17 min at full load , 44 min at half load
- 44.1 cm
- 63.4 cm
- 8.6 cm
- 41.7 kg
