Your basket is empty
Eaton PW5130L3000-EBM2U
Quicklinx: 7H17WS00 Mfr#: 103006589-6591
Type: Battery
Power Rating: [N/A]
£384.15 ex VAT
£460.98 inc VAT
The 2U Extended Battery Module (EBM) gives additional runtime to the Eaton 5130 1250 and 1750 UPSs. Up to 4 EBMs can be attached to each UPS in order to extend the run time to several hours.
Eaton 5130 EBM 3000 RT 2U - battery enclosure
Battery enclosure - rack-mountable / external
Rack Size
2U
41.7 kg
Run Time (Up To)
17 min
44.1 cm x 63.4 cm x 8.6 cm
Height (Rack Units)
2U
Run Time (Up To)
17 min at full load , 44 min at half load
44.1 cm
63.4 cm
8.6 cm
41.7 kg
Type: Battery
Power Rating: [N/A]
Brand: Eaton
Price Range Ex VAT: 300 - 500
