The 2U Extended Battery Module (EBM) gives additional runtime to the Eaton 5130 1250 and 1750 UPSs. Up to 4 EBMs can be attached to each UPS in order to extend the run time to several hours.
- Eaton PW5130N1750-EBM2U Extended Battery Module - UPS battery
- UPS battery - rack-mountable
- Rack Size
- 2U
- 30.4 kg
- 44.1 cm x 50.9 cm x 8.62 cm
- Height (Rack Units)
- 2U
- 44.1 cm
- 50.9 cm
- 8.62 cm
- 30.4 kg
