Eaton PW5130i3000-XL2U
Quicklinx: 7GYSWS00 Mfr#: 103006593-6591
The Eaton 5130 Rack Tower UPS provides line-interactive backup power and scalable runtimes for servers, storage systems, VoIP gear and network equipment. With a two-in-one rack/tower form factor, the 5130 UPS packs up to three kVA of power into only 2U of rack space. The 5130 UPS provides additional battery runtime with 2U extended battery modules. To enhance compatibility with modern IT loads, the 5130 UPS is designed with a 0.9 power factor.
  • High power density
    Compared to earlier generation technologies, the 5130 powers more servers in less space, delivering up to 3000 VA in only 2U - including internal batteries. High power density frees up rack space for more IT equipment, future expansion, or simply to have more room for airflow and heat dissipation.
  • High 0.9 power factor
    Even though it occupies minimal rack space, the 5130 delivers significantly more real output wattage - more real power to your protected load. The difference is a very high 0.9 power factor, a measure of apparent power versus real power. By delivering more real output power, the 5130 powers more servers than another UPS of equivalent VA rating with a lower power factor.
  • Maximum deployment flexibility
    The 5130 can be deployed as a tower unit or in a rack; pedestal and rail kits are included at no extra charge. This UPS also works with a FlexPDU (power distribution unit) from Eaton's Eaton Office Protection Systems series to flexibly distribute power. The PDU enables quick and easy connection of varied load types without help from an electrician - great for responding to frequent moves, adds and changes.
  • More battery runtime for important systems
    If the power goes out, you want to reserve available battery runtime for the most essential loads. With the 5130's load segmentation feature, you can independently control output receptacles. You can shut down power to less essential loads to extend available runtime for more critical devices.
  • Battery runtime for minutes or hours
    During a power outage, internal batteries in the 5130 keep loads running for up to 16 minutes (depending on load), long enough to gracefully shut down systems. You can add more runtime with up to four external battery modules to run systems for hours if necessary.
Eaton PW5130i3000-XL2U - UPS - 2.7 kW - 3000 VA
UPS - external
Rack Size
2U
33.8 kg
Input Voltage
AC 230 V
Output Voltage
AC 184-265 V
Power Capacity
2.7 kW / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid - 7.2 Ah
Battery Form Factor
Internal
Run Time (Up To)
3 min at full load
RS-232, USB
Screwdriver, tower stand, cable retention brackets
44.1 cm x 63.4 cm x 8.62 cm
3-year warranty with product registration
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 294 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 184-265 V
Power Capacity
2.7 kW / 3000 VA
Surge Suppression
Efficiency
94%+
Lead Acid
Voltage Provided
12 V
7.2 Ah
Run Time (Up To)
3 min at full load
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B
Expansion Slots
1 Communication slot
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LED indicators, over voltage protection, undervoltage protection
FCC Class A certified, UL, TUV, C-Tick, ANSI C62.41, cUL, UL 1778, UL 497A, IEC 60950, FCC Part 15, EN 50091-2, CSA C22.2 No. 107.1, EN 50091-1
Software Included
Eaton Intelligent Power Software Suite
Limited warranty - parts and labour - 3 years
35 °C
20 - 95% (non-condensing)
Sound Emission
45 dB
44.1 cm
63.4 cm
8.62 cm
33.8 kg
