Eaton ePDU SW 0U (309 16A 1P) 7XC13:1XC19
Quicklinx: CBCQWS00 Mfr#: ESWB23
£674.27 ex VAT
£809.12 inc VAT
Designed for data centers needing remote site management, the Switched ePDU provides remote power monitoring of both voltage and current. The current is also displayed on a local two-digit current meter. The control interface is highly customizable with multiple functions and flexibility to send either SNMP traps or e-mail alerts.
Eaton ePDU Switched - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
Input Connectors
1 x power IEC 60309 16A
Output connectors
7 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Ethernet 10/100, RS-232
5.2 cm x 6.5 cm x 70.4 cm
Height (Rack Units)
0U
Input Connectors
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) - RJ-45 , 1 x cascading - RJ-45 , 1 x USB - 4 pin USB Type A
Power cable - integrated
LCD display, voltage monitoring, current meter, vertical orientation, firmware upgradable
60 °C
5.2 cm
6.5 cm
70.4 cm
Brand: Eaton
Price Range Ex VAT: £500 - £750
