Eaton ePDU SW 0U (309 16A 1P) 20XC13:4XC19
Quicklinx: CBCXWS00 Mfr#: ESWB04
£840.59 ex VAT
£1,008.70 inc VAT
Designed for data centers needing remote site management, the Switched ePDU provides remote power monitoring of both voltage and current. The current is also displayed on a local two-digit current meter. The control interface is highly customizable with multiple functions and flexibility to send either SNMP traps or e-mail alerts.
Eaton ePDU Switched - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
Input Connectors
1 x power IEC 60309 16A
Output connectors
20 x power IEC 60320 C13 , 4 x power IEC 60320 C19
Ethernet 10/100, RS-232
5.2 cm x 5.3 cm x 160.4 cm
Height (Rack Units)
0U
Input Connectors
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232) - RJ-45 , 1 x cascading - RJ-45 , 1 x USB - 4 pin USB Type A
Power cable - integrated
LCD display, voltage monitoring, current meter, vertical orientation, firmware upgradable
60 °C
5.2 cm
5.3 cm
160.4 cm
