As well as providing a power supply backed up by a battery to keep equipment operating during a power failure, the Ellipse Eco also provides effective protection against damaging surges. The Eco Control function automatically disables peripherals when the master device is turned off in order to save up 25 % more energy compared to previous generation of UPS. This unit can either be placed horizontally, 19 inch rack mounted or wall mounted. The Ellipse Eco also includes the Eaton Intelligent Power Manager software. It is an ideal protection for all business computers.
Energy-efficient power protection for business computers
With an efficient electrical design and the EcoControl function, which automatically disables peripherals when the master device is turned off, the Eaton Ellipse ECO helps you make energy savings of up to 25 percent compared to previous-generation UPSs. As well as providing a power supply backed up by a battery to keep equipment operating during a power failure, the Ellipse ECO also provides effective protection against damaging surges. -
Easy integration and installation
The Ellipse ECO's extra-flat design makes it easy to install in any office environment: installation options include vertical box format, below the desk, horizontally under a monitor and 19" rack-mounted. -
Complete peace of mind
Periodic battery self-test ensures early detection of a battery that needs to be replaced. Easy-to-replace battery helps to extend UPS service life. Push-button circuit breaker enables easy recovery from an overload or short circuit.
- Eaton Ellipse ECO 1600 USB IEC - UPS - 1000 Watt - 1600 VA
- UPS - rack-mountable / external
- Rack Size
- 19" - 2U
- 7.8 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V
- Power Capacity
- 1000 Watt / 1600 VA
- Input Connectors
- 1 x power
- Output connectors
- 4 x power IEC 60320 (UPS and surge) , 4 x power IEC 60320 (surge)
- Battery
- Lead Acid
- Run Time (Up To)
- 11 min at half load
- Networking
- USB
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7
- 8.1 cm x 31.2 cm x 30.5 cm
- 2-year warranty
- Height (Rack Units)
- 2U
- Rack Size
- 19"
- UPS Technology
- Off-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 184 - 264 V
- Input Voltage Range (Adjustable)
- AC 161 - 284 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 11 min at half load , 6 min at 70% load
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- USB cable - external
- Rack Mounting Kit
- Optional
- Wall mountable, audible alarm, LED indicators, deep discharge protection, cold-start function, Eco-efficiency
- CB, IEC 62040-1-1, IEC 62040-2, IEC 60950-1, IEC 61643-1
- Software Included
- Intelligent Power Manager
- OS Required
- Limited warranty - 2 years
- 8.1 cm
- 31.2 cm
- 30.5 cm
- 7.8 kg
