Mazer Type-X is a versatile headset with unique and fascinating illumination. The closed-type headset is pair up with microphone and a specially made tone tuning plate. It is made to bring you optimum bass effect while creating an extraordinary shocking audio experience in an exciting battle.
Mysterious LED illumination
LED illumination system is installed in the headset. Lghts are emitted internally to create a sparking effect. You can switch the light to suit your needs. -
Over-the-head suspension design
The soft cushion of the closed-type headset fits ears perfectly. It is effective to relieve the pressure exert from the headband. The noise canceling function of the headset is superbly great to bring you outstanding gaming experience. -
Switchable microphone button
You can switch on and off the microphone function by just pressing the button of the high quality headset. And you can use the headset by plugging it into the 3.5 mm interface or the USB port. -
Shocking bass effect
The specialized speaker in the headset gives you outstanding bass effect. The crashing sound effect lets you experience the excitement in the fighting games. It is the optimal choice for gaming and music fanatics. -
Multi-function tone tuning plate
Rotatable volume controller is put at the plate. You can control the light effect, adjust the volume or the microphone as you like. Adhesive silicone at the bottom of the plate can be stuck on the smooth surface. It would be very convenient to use.
- E-Blue Mazer Type-X - headset
- Product Type
- Headset - wired
- Additional Functions
- LED lights
- Black
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
- Impedance
- 16 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Controls
- Volume, microphone on/mute
- Product Type
- Headset - wired
- LED lights
- Black
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Wired
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Sensitivity
- 100 dB
- Impedance
- 16 Ohm
- Diaphragm
- 40 mm
Microphone
- Boom
- Mono
- Sensitivity
- -54 dB
Remote Control
- Controls
- Connector Type
- Microphone (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Cable Details
- Headset cable
