Product
Brand
Dynamode RS232 Serial Adapter
Quicklinx: 8JSHWS00 Mfr#: LC232RS
The Dynamode Serial PC Card is the ideal solution for adding a high-speed RS-232 port to portable computers. The internal 16550 UART with its built-in data buffers provides maximum performance for Windows CE, Windows 95/98, Windows NT, Windows 2000 and WinME users to run high-speed peripherals - such as high-speed analog and ISDN modems - without wasting bandwidth re-transmitting missing characters. An industry-standard DB-9 connector is included to connect your portable computer to serial peripherals such as medical and scientific data collection equipment, label printers, bar code scanners, stenographic machines, and external fax/modems. PC Card compatibility and Plug and Play features are assured with full support of all major Card and Socket Services software vendors. A full set of Direct Enablers is also included to support all major socket controllers.
Dynamode LC232RS - serial adapter
Serial adapter
Plug-in module
Interface (Bus) Type
PC Card
Ports
RS-232
5.4 cm x 8.5 cm x 0.5 cm
RS-232
Microsoft Windows 95, Microsoft Windows CE 2.0, Microsoft Windows 98/ME/NT/2000/XP
Serial adapter
Plug-in module
PC Card
Ports
RS-232
Wired
RS-232
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PC Card - type II
FCC
5.4 cm
8.5 cm
0.5 cm
50 °C
10 - 90%
