Product
Brand
Dynamode 27U 800x1000mm 19" Server Cabinet
Quicklinx: 71NQWS00 Mfr#: CAB-FE-27U-8100
Offering excellent quality coupled with value for money, the new LMS Data EcoNetCab Server Enclosure range is ideal for your IT installation, no matter how big or small. Designed to the exacting standards, the Server Enclosure range offer total Server and high valued IT device containment coupled with ease of installation and post maintenance. Used throughout both Public and Private Sector installations across the UK and Europe, they include genuine useful features such as superior hot air venting (both passive and active), heavy duty vertical uprights (both front and back) which can be fully adjusted and multiple cable entry points for correct cable placement. Using Universal mount system means that almost any Server, 19" Network device, Telco/PBX device and of course passive patching systems can be quickly added as and when needed. Apart from the standard 600mm(w) x 1000mm(d) design, the Enclosure is also available as an 800mm(w) x 1000mm(d) design for installations which need more space for cable patching, etc.
Complete Server Cabinet Solutions - Pre-installed with all the basic accessories you need:
  • Fixed Vented Shelf
  • 2 or 4 Way Roof Top Fan Tray
  • Castors & Leveling Feet
  • Bag of M6 Nuts & Screws
  • Front Vertical Cable Management with cover (800mm wide cabinets only)
Main Features:
Available in 600x1000mm and 800x1000mm (with integral cable management system)*
  • Standard, UK Type Free Standing Enclosure
  • Up to 800kg static load capacity
  • Available in 600x600mm, 600x800mm, 800x800mm
  • Welded steel frame
  • Lockable tempered glass front door, the border with integral slotted air vents
  • Lockable steel rear door
  • Keys supplied as standard
  • Front and rear doors are fully reversible instantly
  • Removable side panels with latch, optional lock
  • ETSI standard 19" front and rear adjustable vertical profiles
  • Front, rear and top vented slots for improved air flow
  • Multiple cable entry (gland plates) in the base of the cabinet (slotted for precise cable fit)
  • Integral Electrical Earth connection
  • Adjustable Jacking Feet and Castors are supplied as standard
  • Supplied and fitted vented Shelf
  • Supplied and fitted "roof mount" Fan Tray (populated)
  • Supplied Cabinet nuts and bolt fixings for devices
  • Black Ral 9005 powdered coated finish
  • 800x800mm cabinets include complete vertical cable management system for cable routing
  • Various accessories available
  • Cabinets available as ready assembled or flat pack option
Standard: - Comply with ANS/EIA RS -310-D, IEC297-2, DIN41491 PART1, DIN41491 PART7, GB/T3047.2-92 Standard
Material: - SPCC quality cold rolled steel - Thickness: Mounting profile: 2mm
Loading Capacity: - Static Loading: up to 800kg
  Degree of protection:
- IP20
  Surface Finish:
- Degreasing - Picking - Phosphating - Powder Coated
