Your basket is empty
Dynamode 2.5" SATA & IDE HDD Enclosure USB 2.0
Quicklinx: 5JFDWS00 Mfr#: USB-HD-2.5SI
Type: Storage enclosure
HD Size: 2.5"
Power Supply: None
£5.68 ex VAT
£6.81 inc VAT
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Item: USB 2.0 External Housing for 2.5" SATA + IDE HDD
  • SATA & IDE Portable Hard Disk Caddie
  • Super Slim, anodised aluminium heatsink enclosure
  • High-speed USB Interface- up to 480 Mbps transfer
  • Plug and Play and Hot Swappable
  • Supports IDE or SATA Drives up to 160Gb
  • No Power Supply needed - supplied by USB Bus
  • Supports Windows ME/2000/XP/VISTA and MAC OS 8.6 or higher
  • Dimensions: 125 x 75 x 12mm
Storage enclosure
HD Size
2.5"
Power Supply
USB Powered
HD Size: 2.5"
Power Supply: None
Brand: Dynamode
Price Range Ex VAT: 0 - 50
