Offering excellent quality coupled with value for money, this Wall Mountable Telecom and Data Enclosure is ideal for smaller Networking, SME and branch offices. Designed to the exacting standards, the Wall Mountable range offer a compact and secure containment system for your Rackmount active and passive devices including Switches, branch Routers, Telcom and low density cable patching. Used in both Public and Private Sector installations, this range offer the design features normally found on larger Enclosures such as front U numbering, multiple cable entry points and left/right hand Glass door location. The enclosure (9U and above) also feature a single vented shelf for non Rackmountable devices such as Modems, Access Points and branch Routers.
- Ideal Wall Mounted Enclosures for Home, SME, Retail, Education and restrictive workspace
- If required, can be placed on desk or on the floor
- Standard 19" Front and Rear vertical profiles with choice of depths
- Passive ventilation slots with the option of Rackmount Fan Trays
- Easy to install, can be fixed to most Wall types
- Useful design features including front U numbering, top and bottom cable entry
- Glass front lockable door with left/right fixing for total flexibility
- Removable side panels
- RAL9044 Black powder coated
- Multiple Cable Entry Points
- Supplied with M6 Nuts & Screws
- Ideal for low density Network Switches, Patch Panels, CCTV and Telco systems
- Dimensions: w550 x d550 x h600 (mm)
- Weight: 19kg
- LMS Data EcoNetCab CAB-W12U-EL550 - rack - 12U
- Product Type
- Rack
- Rack Type
- Cabinet
- Placing / Mounting
- Wall mountable
- Black, RAL 9005
- Rack Size
- 19"
- Height (Rack Units)
- 12U
- 55 cm x 55 cm x 60 cm
- Lockable front door, glass door, removable side panels
- Product Type
- Rack
- Rack Type
- Cabinet
- Wall mountable
- Rack Size
- 19"
- 12U
- 55 cm
- 55 cm
- 60 cm
- Black, RAL 9005
