Dynabook Tecra Z40-C-12X Intel Core i5-6200U 4GB 128GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: D14RWS00 Mfr#: PT465E-03E02SEN
Display Size: 14in
Processor Model: I5-6200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 128GB
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
£544.46 ex VAT
£653.35 inc VAT
The Tecra Z40 is a true mobile business notebook, delivering the lightness of an Ultrabook and the powerful processor, plus serious durability, plenty of advanced security features and all the portable performance needed for on-the-go productivity.
Increase on-the-go efficiency with a laptop that's as light as an Ultrabook. It not only increases mobility, it delivers sleek, razor-thin design with a tough exterior for the perfect balance of style and durability.
  • Made for mobile business
    The Tecra Z40-C is ready to do business everywhere. Starting at an ultra-light 1.47 kg and highly robust, it's the perfect companion to take on your travels. Even without an extended battery, you get up to 12.5 hours* on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the 35.6 cm (14") non-reflective Full HD screen. So it's really convenient to type emails or create documents when you're working out of the office - even in dimly-lit conditions, using the illuminated keyboard. *Measured with Mobile Mark 2014.
  • Multi-tasking on the move
    With the latest Intel Core processor up to i7, as well as Intel vPro technology, the Z40-C has all the power you need to multi-task on the move. And with high-performance SSDs and HDDs, the Tecra Z40-C offers plenty of storage, faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease.
  • Fully connected
    The Tecra Z40-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using all three of the USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for optional LTE gives you the freedom to work wirelessly, so you can be more productive anywhere. Connecting to your peripherals is fast and easy with the optional docking solution, which aligns with the other models in Toshiba's latest business line-up. The SD card slot boosts storage too.
  • You can depend on it
    The ultra-durable Portégé Z40-C was designed to withstand the pressures of professional life and meet Toshiba's quality standards. That's why it's backed up by H.A.L.T. (Highly Accelerated Life Test) which simulates 3 years of use. The independent German test institute, TÜV Rheinland has pressure-tested the Z40-C, as well as drop-testing it up to 76 cm, and spill-testing it for resistance up to 30 ml. So even if you accidentally spill your drink, you have time to shut-down and protect your data**. With its light yet strong magnesium chassis, the Portégé Z40-C is robust enough to withstand an ultra-mobile working life, so you can be sure of a higher return on your investment. **Spill-resistant keyboards help protect your data from accidental spills up to 30 ml, allowing you 3 minutes shut down time to save your data. Pressure tested to examine the functionality of the laptop and usage of the LCD screen, after being placed underneath 100kg for 10 seconds.
  • Secure and easy to manage
    The Tecra Z40-C is built for business, and comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z40-C needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The fingerprint and Smartcard reader makes it easy and secure to log on to your PC too, while the 3D sensor knows to take care of your data if your laptop falls.
  • Synergy across devices
    The Tecra Z40-C shares many features with the latest business line-up from Toshiba, to ensure consistency across your company - no matter which models you choose. So you can easily access all of your peripherals using a wide range of ports, with the common docking station. The Z40-C also comes with dongle-free connectivity in the form of HDMI, RGB, Gigabit LAN and three USB 3.0 ports for added convenience and flexibility. All Toshiba laptops share the same software image, for easy customisation in one go. Plus, the fingerprint reader, non-reflective screen, webcam, magnesium chassis, Accupoint and docking connector all come as standard too.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Tecra Z40-C-12X - 14" - Core i5 6200U - 4 GB RAM - 128 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
128 GB SSD
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
DualPoint, ClickPad
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 8.5 hours
Accelerometer
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Steel gray metallic, matte black keyboard
33.8 cm x 23.6 cm x 2.04 cm
1.47 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, DualPoint, ClickPad
Keyboard Backlight
Multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8.5 hours
AC Adapter
Input
AC 120/230 V
Output
19 V, 3.42 A
Connections & Expansion
LAN , HDMI , Headphone/microphone combo jack , 2 x USB 3.0 , VGA , Dock , USB 3.0 (Sleep & Charge)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription)
Case Material
Magnesium alloy
Integrated Options
Accelerometer
Dockable
Security
Administrator password, system password, hard drive password
Theft/Intrusion Protection
Power adapter
TUV Rheinland
Localization
1.47 kg
ENERGY STAR Certified
Display Size: 14in
Optical Storage: None
Graphics: Intel HD Graphics 520
Hard Drive Type: SSD
Brand: Dynabook
Price Range Ex VAT: 500 - 750
