Dynabook Tecra A40-G-10G Intel Core i7-10510U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: G0D5WS00 Mfr#: A1PMZ20E1118
  • Core i7
  • IEEE 802.11n
The Dynabook Tecra A40 is an exceptionally portable, connected and secure 14" business laptop, specifically designed for the modern mobile worker. With a 10th generation CPU and SSD storage within its elegant, ultra-thin and sturdy chassis, the Tecra A40 is ready to meet the security, portability and capability requirements of demanding modern workers.
  • Security comes first
    Dynabook's number one priority will always be your security. The Tecra A40 comes with built-in data protection and our unique in-house BIOS that prevents unauthorised access. Optional biometric login and a range of other authentication features ensure your data is as safe as possible.
  • Meets your demands
    With a 10th generation Intel processor, up to 24 GB or RAM and a fast, reliable SSD, the Tecra A40 can handle multi-tasking and intensive projects, while the non-reflective 14" display keeps information clearly legible, even in bright sunshine.
  • Built to last
    The Tecra A40 is tested to MIL-STD-810 military standards, meaning it is ready to withstand day-to-day bumps and scrapes it's likely to encounter out on the road. As with all Dynabook devices, quality and longevity are assured, so you can rely on your laptop working today, tomorrow and a long time into the future.
  • Connect to anything, anywhere
    The Tecra A40 features a range of connectivity options to keep work moving smoothly. With a Gigabit-LAN port, Intel Wi-Fi-6 and an optional LTE module for 4G connections, you can work without restrictions, in the office or out of it. HDMI, USB Type-C and Micro SD ports allow for a range of accessories and extensions to be added in without issue.
  • Designed for your high standards
    Created, engineered and manufactured in-house by Dynabook's expert technicians, the Tecra A40 delivers reliable results from anywhere. A powerful, long-lasting battery and enhanced connectivity features allow you to work however you want, from anywhere.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Tecra A40-G-10G - 14" - Intel Core i7 - 10510U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (10th Gen) - 10510U / 1.8 GHz (4.9 GHz) / 8 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
14" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Input Device
SecurePad
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
4-cell - up to 10.08 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Tile black (keyboard), black with precious hairline
32.9 cm x 22.9 cm x 1.99 cm
1.47 kg
Environmental Standards
ENERGY STAR Qualified
SAR
0.56 W/kg
EMEA warranty - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (10th Gen) 10510U / 1.8 GHz
Max Turbo Speed
4.9 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
8 GB (provided memory is soldered)
Max RAM Supported
24 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe
Display
14"
Resolution
1920 x 1080 (Full HD)
Widescreen
Anti-reflective
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, two microphones
Input
Keyboard, SecurePad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
Run Time
Up to 10.08 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
2 x USB 3.1 (Sleep & Charge) , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery/data/video) , HDMI , Headphone/microphone combo jack , LAN
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft 365 (30 days trial)
Security
Intel Authenticate
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
SAR Value
0.56 W/kg
1.47 kg
Sustainability Information
ENERGY STAR Certified
Bundled Services
