Dynabook Satellite Pro L50-G-193 Core i7-10510U 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: G0DBWS00 Mfr#: A1PBS12E11ND
Display Size: 15.6in
Processor Model: I7-10510U
Operating System: Windows 10 Pro 64-bit Edition
Hard Drive Capacity: 256GB
Optical Storage: None
  • Core i7
£729.01 ex VAT
£874.81 inc VAT
The Dynabook Satellite Pro L50-G is a well-rounded 15.6" laptop designed to bring the latest technology to an affordable price point. With a 10th generation Intel Core Processor and up to 16 GB of DDR4 RAM within the lightweight chassis, the Dynabook Satellite Pro L50-G can comfortably handle general usage and multi-tasking without slowing down, for up to 11 hours* on a single battery charge. *Measured with Mobile Mark 2014. Mobile Mark is a trademark of Business Applications Performance Corporation.
  • Future-proofed performance that won't break the bank
    Boasting a 10th generation Intel Core Processor and a combination of SSD and HDD storage, alongside a USB Type-C port and powerful Wi-Fi 6, the Dynabook Satellite Pro L50-G is packed with the latest technology and ready for whatever the future holds. All in an affordable package.
  • A truly 'modern device'
    The 'Modern Device' definition from Microsoft specifies certain standards that must be met or exceeded by a Windows 10 device. The Dynabook Satellite Pro L50-G meets these standards so you can rest assured that you're getting a high level of performance, security and design; plus support for Windows 10 user experiences like Cortana voice and Windows Hello biometric login.
  • Built for the office, mobile when needed
    The Dynabook Satellite Pro L50-G has been designed to provide maximum ergonomic comfort for a full day of work. The full-sized keyboard with numeric keypad provides a delightful typing experience, while the precision touchpad makes navigation quick and easy and the anti-glare screen works in any lighting conditions. Yet it's surprisingly thin and light to carry and with up to 10 hours' battery life when you do need to work away from the office. *Measured with Mobile Mark 2014. Mobile Mark is a trademark of Business Applications Performance Corporation.
  • Designed to connect
    A comprehensive set of ports and other options allows the Dynabook Satellite Pro L50-G to connect with your working environment, wherever that may be. Physical ports include USB Type-C, three further USB ports, HDMI and Gigabit LAN, as well as an SD card slot and headphone jack. The USB Type-C port enables a multitude of connections; charge, connect to a display or transfer data, or do it all in one go. The optional USB-C dock allows 1 click connection to minimise cable clutter and quickly hook up all your favourite peripherals.
  • Protects what's precious
    The Dynabook Satellite Pro L50-G is packed with security features to keep your device, and the previous data stored on it, safe and secure. Control access with Windows Hello and Intel Authenticate including biometric options - face authentication and fingerprint reader. An optional Smart Card reader adds a further layer of security while fTPM helps prevent other security attacks. Models with the HD camera feature a slider shutter so you can be sure that your privacy is maintained. And you can physically secure the device via the in-built lock slot.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Satellite Pro L50-G-193 - 15.6" - Core i7 10510U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (10th Gen) 10510U / 1.8 GHz (4.9 GHz) / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Input Device
SecurePad
Numeric Keypad
Integrated Webcam
Bluetooth 5.0, 802.11ax, Gigabit Ethernet
4-cell - up to 9.67 hours
Security
Firmware Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
Black texture, black (keyboard)
36.1 cm x 24.4 cm x 1.99 cm
1.7 kg
Region: United Kingdom
SAR
0.96 W/kg
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.9 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Bezel Type
Raised
Full HD eDP anti-glare
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - Full HD
Camera Features
Privacy shutter, IR camera, Windows Hello
Sound
Stereo speakers, two microphones
Input
Keyboard, SecurePad
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 9.67 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , HDMI , LAN , 2 x USB 3.0 , USB 3.0 (Sleep & Charge) , USB-C 3.1 Gen 1 (Power Delivery/data/video)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
Microsoft 365 (30 days trial)
Security
Administrator password, hard drive password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
SAR Value
0.96 W/kg
Localization
1.7 kg
Graphics: Intel UHD Graphics
Hard Drive Type: SSD
Brand: Dynabook
Price Range Ex VAT: 500 - 750
