The Dynabook Satellite Pro L50-G is a well-rounded 15.6" laptop designed to bring the latest technology to an affordable price point. With a 10th generation Intel Core Processor and up to 16 GB of DDR4 RAM within the lightweight chassis, the Dynabook Satellite Pro L50-G can comfortably handle general usage and multi-tasking without slowing down, for up to 11 hours* on a single battery charge. *Measured with Mobile Mark 2014. Mobile Mark is a trademark of Business Applications Performance Corporation.
Future-proofed performance that won't break the bank
Boasting a 10th generation Intel Core Processor and a combination of SSD and HDD storage, alongside a USB Type-C port and powerful Wi-Fi 6, the Dynabook Satellite Pro L50-G is packed with the latest technology and ready for whatever the future holds. All in an affordable package. -
A truly 'modern device'
The 'Modern Device' definition from Microsoft specifies certain standards that must be met or exceeded by a Windows 10 device. The Dynabook Satellite Pro L50-G meets these standards so you can rest assured that you're getting a high level of performance, security and design; plus support for Windows 10 user experiences like Cortana voice and Windows Hello biometric login. -
Built for the office, mobile when needed
The Dynabook Satellite Pro L50-G has been designed to provide maximum ergonomic comfort for a full day of work. The full-sized keyboard with numeric keypad provides a delightful typing experience, while the precision touchpad makes navigation quick and easy and the anti-glare screen works in any lighting conditions. Yet it's surprisingly thin and light to carry and with up to 10 hours' battery life when you do need to work away from the office. *Measured with Mobile Mark 2014. Mobile Mark is a trademark of Business Applications Performance Corporation. -
Designed to connect
A comprehensive set of ports and other options allows the Dynabook Satellite Pro L50-G to connect with your working environment, wherever that may be. Physical ports include USB Type-C, three further USB ports, HDMI and Gigabit LAN, as well as an SD card slot and headphone jack. The USB Type-C port enables a multitude of connections; charge, connect to a display or transfer data, or do it all in one go. The optional USB-C dock allows 1 click connection to minimise cable clutter and quickly hook up all your favourite peripherals. -
Protects what's precious
The Dynabook Satellite Pro L50-G is packed with security features to keep your device, and the previous data stored on it, safe and secure. Control access with Windows Hello and Intel Authenticate including biometric options - face authentication and fingerprint reader. An optional Smart Card reader adds a further layer of security while fTPM helps prevent other security attacks. Models with the HD camera feature a slider shutter so you can be sure that your privacy is maintained. And you can physically secure the device via the in-built lock slot. -
Services for a flawless performance
The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
- Dynabook Satellite Pro L50-G-132 - 15.6" - Core i5 10210U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Optical Drive
- No optical drive
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel UHD Graphics
- Input Device
- ClickPad
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11ax, Gigabit Ethernet
- Battery
- 4-cell - up to 10.33 hours
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- Black texture, black (keyboard)
- 36.1 cm x 24.4 cm x 1.99 cm
- 1.7 kg
- Localisation
- Region: United Kingdom
- SAR
- 0.96 W/kg
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Bezel Type
- Raised
- HD+ eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Camera Features
- Privacy shutter
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, ClickPad
- Numeric Keypad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 200
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 10.33 hours
Connections & Expansion
- Headphone/microphone combo jack , HDMI , LAN , 2 x USB 3.0 , USB 3.0 (Sleep & Charge) , USB-C 3.1 Gen 1 (Power Delivery/data/video)
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft 365 (30 days trial)
- Security
- Administrator password, hard drive password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- SAR Value
- 0.96 W/kg
- Localization
- 1.7 kg
