Dynabook Portege X30-F-12M Intel Core i7-8565U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: FGVBWS00 Mfr#: PUR31E-028006EN
Display Size: 13.3in
Processor Model: I7-8565U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
Hurry, only 1 left in stock!
£1,151.12 ex VAT
£1,381.34 inc VAT
The Portégé X30 powers through your workload with powerful CPU, and doesn't overheat, thanks to Hybrid Air Cooling technology - so everything runs fast, and runs smoothly, even in a sleek and light chassis.
  • Power in a slim package
    At 15.9 mm thin and 1.05 kg light, the Portégé X30-F helps you power through any task, anywhere. The innovative Intel Optane SSD shortens waiting times and speeds up your output, while the latest Intel Wi-Fi modules connect using 802.11ax for improved security, higher throughput and improved network capacity. The Portégé X30-F can always keep up too: its new S-Type cooling system works tirelessly and quietly to protect against overheating.
  • Work with confidence
    We built the Portégé X30-F with security at its core – and our own unique in-house BIOS is the foundation. With two-factor authentication, including IR-based Windows Hello and fingerprint reader, this machine is easy to access in the right hands, and almost impenetrable in the wrong ones. Wake the Portégé X30-F up instantly using the wake on fingerprint feature, then access information straight away - without having to wait to reconnect - thanks to modern standby.
  • The world is your office
    When you're working on the move, you need a laptop that can keep up. That's why we equipped the Portégé X30-F with a FHD non-reflective screen including optional In-Cell Touch technology – so whatever the lighting conditions, you can access content fast and watch it with clarity. You can connect on the go too, with optional mobile broadband including LTE.
  • The tools to achieve
    If you're a high performer, the Portégé X30-F is your perfect partner. Its sturdy honeycomb-structured magnesium chassis is armed with the latest technology – including twin USB Type-C Thunderbolt 3 enabled ports for extendable connectivity. Meanwhile the blistering fast Intel Optane SSD drive with up to 1 TB of space gives you the power you need to fulfil your potential.
  • Immaculate presentation
    The way you present content to your peers, clients and managers can make all the difference. So we added Harman/Kardon speakers with DTS for crisp sound that helps everyone in the room hear you loud and clear. And with an HDMI port that allows you to share on-screen content with a larger display or TV, they'll have a crystal-clear view too.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Portégé X30-F-12M - 13.3" - Core i7 8565U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
AccuPoint, SecurePad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
3-cell - up to 10.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Tile matte black (keyboard), onyx blue with hairline
31.6 cm x 22.7 cm x 1.64 cm
1.05 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
470 cd/m²
Anti-reflective
Audio & Video
Graphics Processor
Camera
Camera Features
IR camera, Windows Hello
Sound
Harman/kardon stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, AccuPoint, SecurePad
Keyboard Backlight
Glass finished Securepad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Wi-Fi CERTIFIED
3-cell Lithium Ion
Run Time
Up to 10.5 hours
AC Adapter
Input
Output
20 V, 2.25 A
Connections & Expansion
Headphone/microphone combo jack , HDMI , USB 3.0 (Sleep & Charge) , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery/data/video)
Software
Software Included
Microsoft Office 365 (30 days trial)
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
Localization
1.05 kg
ENERGY STAR Certified
Software applications
Dynabook Portege X30-F-12M Intel Core i7-8565U 8GB 256GB SSD 13.3 Bundle deal on Dynabook Portege X30-F-12M Intel Core i7-8565U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
£1,250.29
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Dynabook
Price Range Ex VAT: 1000 - 1500
