Dynabook Portege A30-E-14Q Intel Core i7-8550U 16GB 1TB SSD 13" Windows 10 Professional 64-bit
Quicklinx: FGWDWS00 Mfr#: PSZ10E-03N006EN
  • Core i7
  • IEEE 802.11n
The freedom to perform
Designed, engineered and manufactured in-house to dynabook’s rigorous quality standards, the Portégé A30-E delivers unrivalled productivity and reliability on the move, with portable convenience to create and collaborate. A powerful, long-lasting battery, high-brightness no-glare screen and optional LTE, which means there is freedom to work effectively anywhere.
No limitations
Durability, reliability and strength are at the heart of the Portégé A30-E. Tested to MIL-STD-810 military standards and ready for any situation that the working day can throw at it, this laptop is built to last. Expect endurance, a long lifecycle and a healthy ROI.
Safe and secure, always
Business security is taken care of with the Portégé A30-E. Built-in data protection includes unique in-house BIOS for maximum security, plus TPM, biometric login and a wide range of optional authentication features to ensure your data doesn’t fall into the wrong hands. Optional smartcard, two-factor authentication, including IR-based Windows Hello and inbuilt fingerprint reader, and even a special slimline lock to keep the device physically secure all guarantee peace of mind.
Fast, reliable connectivity
dynabook’s Portégé A30-E has an extensive range of connectivity options, from a Gigabit-LAN port to Intel® Dual Band Wireless-AC 8265 2X2 WIFI Antenna and everything in between. This guarantees fast, reliable network connections in the office, at home or on the go, allowing collaboration and creativity to flow everywhere. USB Type-C ensures a multitude of connections to charge, connect to a display or transfer data, or do all three at once.
Engineered to excel
The Portégé A30-E has been designed and engineered in-house to deliver maximum processing power in an ultra-thin and light form factor. With an 8th generation CPU and SSD hard drive, this device is built to run even the most demanding programs and multitask efficiently with DDR4 RAM that’s expandable to 24 GB. Unrivalled productivity and reliability provide the power to conquer every challenge of the working day.
  • The freedom to perform
    Designed, engineered and manufactured in-house to Dynabook's rigorous quality standards, the Portégé A30-E delivers unrivalled productivity and reliability on the move, with portable convenience to create and collaborate. A powerful, long-lasting battery, high-brightness no-glare screen and optional LTE, which means there is freedom to work effectively anywhere.
  • No limitations
  • Safe and secure, always
    Business security is taken care of with the Portégé A30-E. Built-in data protection includes unique in-house BIOS for maximum security, plus TPM, biometric login and a wide range of optional authentication features to ensure your data doesn't fall into the wrong hands. Optional smartcard, two-factor authentication, including IR-based Windows Hello and inbuilt fingerprint reader, and even a special slimline lock to keep the device physically secure all guarantee peace of mind.
  • Fast, reliable connectivity
    Dynabook's Portégé A30-E has an extensive range of connectivity options, from a Gigabit-LAN port to Intel Dual Band Wireless-AC 8265 2X2 Wi-Fi Antenna and everything in between. This guarantees fast, reliable network connections in the office, at home or on the go, allowing collaboration and creativity to flow everywhere. USB Type-C ensures a multitude of connections to charge, connect to a display or transfer data, or do all three at once.
  • Engineered to excel
    The Portégé A30-E has been designed and engineered in-house to deliver maximum processing power in an ultra-thin and light form factor. With an 8th generation CPU and SSD hard drive, this device is built to run even the most demanding programs and multitask efficiently with DDR4 RAM that's expandable to 24 GB. Unrivalled productivity and reliability provide the power to conquer every challenge of the working day.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Portégé A30-E-14Q - 13.3" - Intel Core i7 - 8550U - 16 GB RAM - 1 TB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) - 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
16 GB DDR4 (1 x 8 GB + 8 GB (soldered))
Storage
1 TB SSD
Display
13.3" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
SecurePad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell - up to 8.75 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Tile black (keyboard), black with precious hairline
31.6 cm x 22.7 cm x 1.99 cm
1.2 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
SAR
0.79 W/kg
EMEA warranty - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8550U / 1.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
RAM
16 GB (1 x 8 GB + 8 GB (soldered))
Max RAM Supported
24 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
Slots Qty
1
Empty Slots
0
Storage
Main Storage
1 TB SSD M.2 PCIe
Display
13.3"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
470 cd/m²
Anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers
DTS Studio Sound
Input
Keyboard, SecurePad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8.75 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , HDMI , 2 x USB 3.1 (Sleep & Charge) , USB-C 3.1 Gen 2 (Power Delivery/data/video) , LAN
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft 365 (30 days trial), DTS Studio Sound
Security
Administrator password, Intel Authenticate
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
SAR Value
0.79 W/kg
Localization
1.2 kg
Sustainability Information
ENERGY STAR Certified
Bundled Services
