Advanced Labeling Tool. Go for the portable, affordable label printer that builds your reputation. Show off your work with Rhino 5200 from DYMO Industrial - the label printer for datacomm, electrical, audio/visual, security, MRO, construction and broadcast professional.
- DYMO Rhino 5200 - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 900 g
- Max Media Size
- Roll (1.9 cm)
- Min Media Size (Custom)
- 6 mm
- Max Media Size (Custom)
- 19 mm
- Cutter
- Barcodes
- Code 39, Code 128
- Media Type
- Flexible nylon tape, permanent adhesive vinyl tape, polypropylene inserts, permanent adhesive polyester tape
- Character Sizes
- 7 sizes
- Styles & Effects
- Bold, narrow, italic, underline, boxes around text
- Battery
- Required 6 x AA type
- 2-year warranty with product registration
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Built-in Devices
- Preview screen, character keyboard
- Character Sizes
- 7 sizes
- Styles & Effects
- Auto Cutter
- Barcodes
- Code 39, Code 128
Media Handling
- Media Type
- Max Media Size
- Roll (1.9 cm)
- 6 mm
- 19 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
- Media Feeders
- 1 x manual - 1 cassette - Roll (1.9 cm)
- Rugged
- CISPR 22 Class B, CISPR 24, EN 61000-3-2, IEC950, UL 1950, EN 61000-3-3, EN55024, EN55022 Class B, EN 61000-6-1, FCC Part 15 B, AS/NZS 60950-1, EN 61000-4-4, EN 61000-4-2, EN50204, EN 61000-4-3, EN 61000-4-6, EMC, EN 61000-4-5, EN 55020, CISPR 13, CISPR 20, EN55013, EN 61000-4-11, EN 61000-4-8, UL 60950-1, EN 60950-1, WEEE, EN 61000-6-3, UL 2054
- AA type
- Required Qty
- 6
- Limited warranty - 2 years
- 900 g
DYMO Black on white 12mm col vinyl | In Stock | £14.53 |
DYMO ID1 19mm - 1300mm Flexible Nylon - White | In Stock | £18.21 |
