RHINO 5200 from DYMO industrial - the portable, affordable label printer is for datacomm, electrical, audio/visual, security, MRO, construction and broadcast professionals. It's easier than ever to give your installations a neat, professional look that builds your reputation! Fast, rugged and packed with time-saving features, RHINO 5200 meets all ANSI, TIA/EIA-606-A labeling standards, and is designed for professional installers in real-world jobsite conditions. Hot-keys - a RHINO exclusive - make it easy to print pre-formatted labels for wire and cable, terminal blocks, 110 blocks, electrical and patch panels, vertical and fixed lengths. An extensive pre-programmed symbol library puts industry symbols, basic punctuation, currency and fractions at your fingertips. Separate "save" and "recall" buttons prevent repeated work, and smart onscreen alerts help prevent mistakes and wasted labels. Built to perform wherever you work, RHINO 5200 includes an integrated, slip-resistant rubber grip/bumper that protects against damage from accidental bumps and falls, and an integrated lanyard loop for option of hands-free portability.
- DYMO Rhino 5200 - labelmaker - B/W
- Printer Type
- Labelmaker - B/W
- Form Factor
- Portable
- 0.9 kg
- Max Media Size
- Roll (1.9 cm)
- Max Media Size (Custom)
- 19 mm
- Cutter
- Barcodes
- Code 39, Code 128
- Media Type
- Flexible nylon tape, permanent adhesive vinyl tape, permanent adhesive polyester tape, non-adhesive tag
- Character Sizes
- 7 sizes
- Styles & Effects
- 6 styles
- Battery
- Required 6 x AA type
- Printer Type
- Labelmaker - monochrome
Printer
- Built-in Devices
- Preview screen, character keyboard, cutter
- Character Sizes
- 7 sizes
- Styles & Effects
- 6 styles
- Cutter
- Barcodes
- Code 39, Code 128
Media Handling
- Media Type
- Max Media Size
- Roll (1.9 cm)
- 19 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
- Media Feeders
- 1 x manual - 1 cassette - Roll (1.9 cm)
- Media Included
- 1 19mm white flexible nylon tape
- AA type
- Required Qty
- 6
- 0.9 kg
