DYMO Printer Server
Quicklinx: 9770WS00 Mfr#: S0929090
Wired / Wireless: Wired
Protocol: Ethernet
Form Factor: External
Interface: USB
Compatibility: Mac, PC
11 in stock
£77.74 ex VAT
£93.28 inc VAT
LabelWriter Print Server allows you to share your LabelWriter printers with your co-workers, connect any LabelWriter 400 or 450 series printer to your network and maximize your LabelWriter label printer usage. Easy set up - just plug in the power supply, connect to a network jack and your LabelWriter printer, and install the software on a single workstation. No extra cables required.
DYMO - print server
Print server
External
Interface (Bus) Type
USB
United Kingdom
10Mb LAN
Microsoft Windows XP, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista (32/64 bits)
DYMO LabelWriter 400, 400 Duo, 400 Turbo, 400 Twin Turbo, 450, 450 Duo, 450 Turbo, 450 Twin Turbo, 4XL
Print server
External
USB
United Kingdom
Wired
Ethernet
1 x Ethernet - RJ-45
1 x USB
Power adapter - external
9770 C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
9770 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.10
9770 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.97
Protocol: Ethernet
Interface: USB
Compatibility: Mac
Compatibility: PC
Brand: DYMO
Price Range Ex VAT: 50 - 100
