DYMO LetraTAG LT100H Mono Label Maker
Quicklinx: 8HNTWS00 Mfr#: S0883980
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
More than 50 in stock
£16.85 ex VAT
£20.22 inc VAT
Label and organize anywhere in your home. Small, Sleek and super portable, the hand-held DYMO LetraTag LT00H makes it easy to organize each and every room in your home.
DYMO LetraTag LT-100H - labelmaker - B/W - direct thermal
Printer Type
Labelmaker - direct thermal - B/W
Portable
280 g
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
12 mm
Max Resolution (B&W)
160 dpi
Media Type
Iron-on tape, paper tape, metallic tape, plastic tape
Compatible Tapes
LetraTag tape
Character Sizes
5 sizes
Styles & Effects
Bold, normal, vertical, outline, shadow, italic, underline, boxes around text
1 line printing, 2 line printing, realtime clock
Display Resolution
1 line x 13 characters / 50 x 25
Keyboard
ABCD / 45 keys
Required 4 x AA type Included Qty 0
9.5 cm x 21.5 cm x 6.5 cm
Printer Type
Labelmaker - direct thermal - monochrome
Printer
Built-in Devices
Preview screen, character keyboard, cutter
160 dpi
Character Sizes
5 sizes
Styles & Effects
Display Resolution
Keyboard
ABCD / 45 keys
Media Handling
Media Type
Compatible Tapes
LetraTag tape
Max Media Size
Roll (1.2 cm)
12 mm
Media Sizes
Roll (1.2 cm)
Media Feeders
1 x manual - 1 cassette - Roll (1.2 cm)
Consumables Included
1 x tape cassette
AA type
Required Qty
4
Included
0
9.5 cm
21.5 cm
6.5 cm
280 g
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (1.2 cm)
Brand: DYMO
Price Range Ex VAT: 0 - 50
