Product
DYMO LabelWriter 450 Twin Turbo
Quicklinx: 9B0RWS00 Mfr#: S0838910
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£131.89 ex VAT
£158.26 inc VAT
Maximize your labeling and mailing efficiency. The DYMO LabelWriter 450 Twin Turbo label printer holds two label rolls, so you can print labels and postage even faster. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 450 Twin Turbo - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
0.68 kg
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Max Resolution (B&W)
600 x 300 dpi
USB
Media Type
Thermal labels
Total Media Capacity
2 rolls
2 years warranty
21.7 cm x 18.8 cm x 13.5 cm
Printer Type
Printer
Wired
USB
600 x 300 dpi
Media Handling
Media Type
Thermal labels
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (6.2 cm)
Max Printing Width
56 mm
2 rolls
1 x USB 2.0
TUV, TUV GS, C-Tick, IEC 60950, CB, FCC Part 15 B, FCC, cTUVus
Power adapter - external
Software Included
DYMO Label Software 8
21.7 cm
18.8 cm
13.5 cm
0.68 kg
9B0R DYMO labelWriter Large Address Labels White In Stock £13.73
Type: Printer
Max Print Speed: [N/A]
Brand: DYMO
Price Range Ex VAT: 100 - 150
