DYMO LabelWriter 450 Turbo Mono Direct Thermal Label Printer
Quicklinx: 6KFYWS00 Mfr#: S0838860
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
19 in stock
£109.42 ex VAT
£131.30 inc VAT
The LabelWriter 450 Turbo prints impressive labels at very high speeds, taking office labeling to another level. Professional labeling and mailing solution for your busy office. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 450 Turbo - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
0.68 kg
Max Media Size
Roll (6.2 cm)
Max Media Size (Custom)
62 mm
Print Speed
Up to 71 labels/min - B/W - Roll (6.2 cm)
Max Resolution (B&W)
600 x 300 dpi
USB
Media Type
Labels, thermal paper
Microsoft Windows XP, Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits)
12.4 cm x 18.4 cm x 14.6 cm
Printer Type
Printer
Print Speed
Wired
USB
600 x 300 dpi
Media Handling
Media Type
Max Media Size
Roll (6.2 cm)
62 mm
Media Sizes
Roll (6.2 cm)
Max Printing Width
56 mm
Media Feeders
1 x manual - 1 roll - Roll (6.2 cm)
1 x USB 2.0
FCC Class B certified, TUV, TUV GS, C-Tick, IEC 60950, CB, FCC Part 15, FCC, cTUVus
Power adapter - external
Software Included
DYMO Label Software 8
12.4 cm
18.4 cm
14.6 cm
0.68 kg
Ink (4)
6KFY DYMO labelWriter Large Address Labels White In Stock £12.46
6KFY DYMO LabelWrtier Standard Address Labels In Stock £7.06
6KFY DYMO 11353 Multi-use Labels In Stock £11.74
6KFY DYMO LabelWriter MultiPurpose - multi-purpose labels - 500 label(s) - 19 x 51 mm In Stock £6.68
Other bundles (3)
6KFY C2G 2m USB 2.0 A/B Cable - Black In Stock £3.84
6KFY C2G 5m USB 2.0 A/B Cable - Black In Stock £5.16
6KFY C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.26
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (6.2 cm)
Brand: DYMO
Price Range Ex VAT: 100 - 150
