DYMO LabelWriter 450 Mono Direct Thermal Label Printer
Quicklinx: 6KRJWS00 Mfr#: S0838810
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
More than 50 in stock
£77.79 ex VAT
£93.34 inc VAT
Effective label printing for any budget. Professional labeling and mailing solution for your busy office. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
DYMO LabelWriter 450 - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
654 g
Max Media Size
Roll (6.2 cm)
Print Speed
Up to 51 labels/min - B/W
Max Resolution (B&W)
600 x 300 dpi
USB 2.0
Media Type
Labels, thermal paper
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
3-year warranty with product registration
12.7 cm x 18.7 cm x 13.4 cm
Printer Type
Printer
Print Speed
Wired
USB 2.0
600 x 300 dpi
Media Handling
Media Type
Max Media Size
Roll (6.2 cm)
Media Sizes
Roll (6.2 cm)
Max Printing Width
56 mm
Media Feeders
1 x manual - 1 roll - Roll (6.2 cm)
1 x USB 2.0
1 x USB cable
TUV, TUV GS, C-Tick, CB, FCC, WEEE, cTUVus
Power adapter - external
Software Included
DYMO Label Software 8
Limited warranty - 3 years
12.7 cm
18.7 cm
13.4 cm
654 g
Ink (4)
6KRJ DYMO labelWriter Large Address Labels White In Stock £12.46
6KRJ DYMO LabelWrtier Standard Address Labels In Stock £7.08
6KRJ DYMO 11353 Multi-use Labels In Stock £11.79
6KRJ DYMO LabelWriter MultiPurpose - multi-purpose labels - 500 label(s) - 19 x 51 mm In Stock £6.68
Other bundles (2)
6KRJ C2G .45m USB to DB9 Serial Adapter Cable In Stock £12.51
6KRJ C2G 2M DB9 M/F ALL LINES EXT CBL BLK In Stock £5.14
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (6.2 cm)
Brand: DYMO
Price Range Ex VAT: 50 - 100
