Print the widest variety of DYMO labels with one versatile printer. With the ability to print paper and permanent D1 plastic labels, you're ready to tackle virtually any labeling job. Connect a DYMO LabelWriter label printer to your PC or MAC and you're ready to print address labels, file folder labels, name badges and much more. LabelWriter label printers make it easy to get first-class results. Thermal printing technology eliminates the cost of ink and toner and the hassle of sheet labels, forever. Improved resolution graphics mode delivers crystal Clear text, graphics and barcodes. Sleep mode conserves energy. Put it anywhere - its compact design fits in to any modern workspace.
- DYMO LabelWriter 450 Duo - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 71 labels/min - B/W
- Max Resolution (B&W)
- 600 x 300 dpi
- Interface
- USB
- Media Type
- Labels, thermal paper, plastic tape
- Compatible Tapes
- D1 tape
- System Requirements
- Microsoft Windows XP, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits)
- 12.7 cm x 19.7 cm x 18.4 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 600 x 300 dpi
Media Handling
- Media Type
- Compatible Tapes
- D1 tape
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (5.4 cm), Roll (2.4 cm), Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm), Roll (3.8 cm), Roll (3.6cm), Roll (5.1cm), Roll (3.2 cm), Roll (2.5 cm), Roll (6.2 cm), Roll (2.8 cm), Roll (5.9 cm)
- Max Printing Width
- 56 mm
- Connections
- 1 x USB
- Included Accessories
- Cleaning kit
- Cables Included
- 1 x USB cable
- Power Device
- Power adapter - external
- Software Included
- DYMO Label Software 8
- OS Required
- 12.7 cm
- 19.7 cm
- 18.4 cm
DYMO labelWriter Large Address Labels White | In Stock | £12.46 |
DYMO LabelWrtier Standard Address Labels | In Stock | £7.22 |
