Touch Screen Label maker with PC or MAC connection. The first standalone office touch screen label maker from DYMO.
- DYMO LabelMANAGER 500TS - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- 0.8 kg
- Localisation
- Hong Kong, United Kingdom
- Max Media Size
- Roll (2.4 cm)
- Max Resolution (B&W)
- 300 dpi
- Interface
- USB
- Media Type
- Labels
- Compatible Tapes
- D1 tape
- Fonts
- 10 fonts
- Character Sizes
- 25 sizes
- Styles & Effects
- Bold, normal, vertical, outline, italic, Mirror, strikethrough
- Keyboard
- QWERTY
- Battery
- Required 1 Included Qty 1
- Enclosure Colour
- Black, silver
- 3-year warranty with product registration
- 16.5 cm x 19 cm x 9.5 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
- Enclosure Colour
- Black, silver
- Localisation
Printer
- Built-in Devices
- Character keyboard, touch screen, cutter
- Connectivity Technology
- Wired
- Interface
- USB
- 300 dpi
- Fonts
- 10 fonts
- Character Sizes
- 25 sizes
- Styles & Effects
- Auto Cutter
- Keyboard
- QWERTY
Media Handling
- Media Type
- Labels
- Compatible Tapes
- D1 tape
- Max Media Size
- Roll (2.4 cm)
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (1.9 cm)
- Media Feeders
- 1 x manual - 1 roll - Roll (2.4 cm)
- Connections
- 1 x USB
- Cables Included
- 1 x USB cable
- Power Device
- Power adapter - external
- Required Qty
- 1
- Included
- 1
- Limited warranty - 3 years
- 16.5 cm
- 19 cm
- 9.5 cm
- 0.8 kg
