Brand
DYMO Generic S50 Shipping Scales 50KG UK
Quicklinx: 8MWCWS00 Mfr#: S0929050
£112.25 ex VAT
£134.70 inc VAT
With a handy wrap round handle the DYMO S50 digital USB shipping scales are easily portable. Designed in heavy duty material they are ideal for any warehouse or mailing room, weighing upto 50kg.
If your package is of a cumbersome shape, then the S50 has it covered. Not only does this allow parcels to be weighed in a container, giving you the weight minus the container, but you also benefit from a large platform area of 30 x 30 cm.
A great feature of the DYMO S50 is the detachable LCD screen which can be wall mounted or hand held for easy weight viewing. There is also the ability of using the hold feature on the LCD display if extra time is required to view the weight displayed.
Brand: DYMO
