Your basket is empty
Duracell Ultra Fast Battery Charger
Quicklinx: 7XV3WS00 Mfr#: DR5502-UK
The Duracell Ultra fast camcorder and digital camera battery charger is a fantastic product that can fully charge you camera and camcorder battery in under 30 minutes. The charger is supplied with a mains wall adapter for use around the home as well as a 12v in-car cigarette lighter adapter so that you can charge your battery when you are out and about.
This charger has a clever LED guage which indicates the status of a charge at any time as well as in built safety feature meaning it will never over charge your battery.The charger is compatible with the most popular camera and camcorder batteries and additional plates can be purchased for other batteries in the future.
Charges a battery in as little as 28 minutes.
Over-voltage and short circuit protection.
LED fuel gauge to indicate charge status.
Duracell DR5502-UK - battery charger - AC / car
Battery charger - AC / car
12.4 cm x 6.7 cm x 2.9 cm
146 g
United Kingdom
AC 230 V
3 years warranty
12.4 cm
6.7 cm
2.9 cm
146 g
United Kingdom
AC 230 V
Input Connectors
Power, car cigarette lighter
LED indicator, short circuit protection, over voltage protection
AC power adaptor
Car connection cable
3 years warranty
Service & Support Details
Limited warranty - 3 years
