This high-quality Duracell original camera battery will see you snapping again in no time at all.
The Duracell multi-fit camera battery provides long-lasting lithium-ion power for a range of camera makes and models, allowing hundreds of photos to be taken on a single charge.
Duracell digital camera and camcorder batteries are built to the highest possible standards - something you would expect from such a respected brand.
Each battery has a 2-year limited warranty, protecting you whatever happens.
Duracell camera and camcorder batteries deliver equivalent performance to the manufacturers original and are supplied with a 2 year limited warranty
- Duracell battery - Li-Ion
- Product Type
- Battery
- Designed For
- Camera
- 3.9 cm x 3 cm x 0.6 cm
- Black
- Battery
- Lithium Ion - 0.63 Ah
- 3-year warranty
- Designed For
- Fujifilm FinePix J100, J110, J120, J150, J20, J250, Z200, Z30, Z33; Nikon Coolpix S220, S230, S60; Olympus C-25, C-520, C-540, C-550, C-560, C-570, FE-220, 3000, 3010, 350, 5000, 5010, X-15, X-790, X-795, X-800, X-820, X-825, X-830, X-855, X-865, X-875, X-905, X-915; µ[MJU:] 720; CAMEDIA D-630
- Product Type
- Battery
- Designed For
- Camera
- 3.9 cm
- 3 cm
- 0.6 cm
- Enclosure Colour
- Black
- Technology
- Lithium Ion
- Voltage Provided
- 3.7 V
- Capacity
- 0.63 Ah
- Limited warranty - 3 years
- Designed For
- Fujifilm FinePix J100, J110w, J120, J150w, J20, J250, Z100fd, Z10fd, Z200fd, Z20fd, Z30, Z33WP , Nikon Coolpix S200, S210, S220, S230, S500, S510, S520, S60, S600, S700 , Olympus C-25, C-520, C-540, C-550, C-560, C-570, FE-190, FE-20, FE-220, FE-220D, FE-230, FE-240, FE-250, FE-280, FE-290, FE-300, FE-3000, FE-3010, FE-320, FE-330, FE-340, FE-350, FE-350 Wide, FE-360, FE-5000, FE-5010, IR-300, X-15, X-750, X-785, X-790, X-795, X-800, X-820, X-825, X-830, X-835, X-845, X-855, X-865, X-875, X-905, X-915 , Olympus µ[MJU:] 720 SW, 780, 790 SW, 795 SW, 830 , Olympus CAMEDIA D-630 Zoom, FE-5500, X-600
