-Duracell rectangular shaped battery with three contacts points on one side.
-100% OEM compatible.
-Guaranteed to meet or exceed OEM specifications.
- Duracell camera battery - Li-Ion
- Product Type
- Camera battery
- 4 cm x 3.5 cm x 0.6 cm
- Battery
- Lithium Ion 0.72 Ah
- 3 years warranty
- Designed For
- Kodak EASYSHARE M1063, M1073 IS, M320, M340, M753, M763, M853, M863, M893 IS, V550, V570 Dual Lens, V610 Dual Lens, V705
- Product Type
- Camera battery
- 4 cm
- 3.5 cm
- 0.6 cm
- Technology
- Lithium Ion
- Voltage Provided
- 3.7 V
- Capacity
- 0.72 Ah
- Limited warranty - 3 years
- Designed For
