Duracell Rechargeable 9V single
High performance 9V 170 mAh batteries.
Please note this battery is not suitable for smoke alarms due to the quick discharge properties of rechargeable batteries.Can be recharged upto 1000 times. Great for the environment and your pocket.
- Duracell HR9V Multipurpose Battery battery x 9V - NiMH
- Product Type
- Battery
- 4.9 cm x 2.6 cm x 1.7 cm
- 65 g
- Battery
- 9V - Nickel Metal Hydride - 170 mAh - ( rechargeable )
- 3-year warranty
- Product Type
- Battery - ( rechargeable )
- 4.9 cm
- 2.6 cm
- 1.7 cm
- 65 g
- 9V
- Technology
- Voltage Provided
- 9 V
- Capacity
- 170 mAh
- Max Recharge Cycles
- 1000
- Limited warranty - 3 years
