Product
Duracell Dual USB 2.4A & 1A Wall Charger
Quicklinx: 9BPYWS00 Mfr#: DR6001A
This Duracell USB charger has all the plug sockets you'll ever need while traveling or in the home and is the must have accessory for charging your tablet and smartphone simultaneously. The 2 USB sockets provided are rated at 1 A for conventional smartphones, iPod and Blackberry with the 2.4 A socket suitable for tablets. A light indicates power is being supplied to connected devices. The DR6001 is perfect for charging your phone and tablet simultaneously.
Duracell power adapter
Power adapter
6.2 cm x 2.5 cm x 5 cm
84 g
Australia, United Kingdom, United States, Europe
Output Connector Type
USB
AC 110-240 V
Voltage Provided
5 V
Power Device Details
- 4 pin USB Type A - 5 V - 2.4 A , - 4 pin USB Type A - 5 V - 1 A
3 years warranty
Power adapter
6.2 cm
2.5 cm
5 cm
84 g
AC 110-240 V
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Max Electric Current
2.4 A
4 pin USB Type A - 5 V - 2.4 A , 4 pin USB Type A - 5 V - 1 A
LED indicator
4 international adapter plugs
Limited warranty - 3 years
