This Duracell USB charger has all the plug sockets you'll ever need while traveling or in the home and is the must have accessory for charging your tablet and smartphone simultaneously. The 2 USB sockets provided are rated at 1 A for conventional smartphones, iPod and Blackberry with the 2.4 A socket suitable for tablets. A light indicates power is being supplied to connected devices. The DR6001 is perfect for charging your phone and tablet simultaneously.
- Duracell power adapter - USB
- Product Type
- Power adapter
- 6.2 cm x 2.5 cm x 5 cm
- 84 g
- Localisation
- Australia, United Kingdom, United States, Europe
- Output Connector Type
- Total 2: USB
- Voltage Required
- AC 110-240 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2.4 A
- Power Device Details
- - 4 pin USB Type A - 5 V - 2.4 A , - 4 pin USB Type A - 5 V - 1 A
- 3-year warranty
- Product Type
- Power adapter
- 6.2 cm
- 2.5 cm
- 5 cm
- 84 g
- Localisation
- Voltage Required
- AC 110-240 V
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- 2.4 A
- 4 pin USB Type A - 5 V - 2.4 A , 4 pin USB Type A - 5 V - 1 A
- LED indicator
- Included Accessories
- 4 international adapter plugs
- Limited warranty - 3 years
