Your basket is empty
Duracell DR5700G-UK - Battery Charger
Quicklinx: 7VMHWS00 Mfr#: DR5700G-UK
The Duracell compact battery charger is a fantastic product that can fully charge your camera and camcorder battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home.
This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery. The charger is compatible with the popular camera and camcorder batteries.
General / Subcategory (MG)
Power adapters and chargers
Header / Manufacturer
Duracell
Header / Model
DR5700G-UK
General / Designed For (MG)
Camera
General / Product Type
Battery charger
Power Device / Voltage Required
AC 110-240 V
Service & Support / Type
3 years warranty
Header / Packaged Quantity
1
