The Duracell compact battery charger is a fantastic product that can fully charge your camera and camcorder battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home.
This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery. The charger is compatible with the popular camera and camcorder batteries.
- Duracell DR5700LM-UK battery charger
- Product Type
- Battery charger
- Localisation
- Hong Kong, United Kingdom
- Voltage Required
- AC 230 V
- 3-year warranty
- Designed For
- Samsung Digimax Battery Pack SLB-1137; Digimax Power Pack SLB-1137KIT; SLB-0637, 0737, 0837, 0837A, 10A, 1137, 1137C, 1137D
- Product Type
- Battery charger
- Designed For
- Camcorder, camera
- Localisation
- Voltage Required
- AC 230 V
- LED indicator
- Limited warranty - 3 years
- Designed For
- Samsung Digimax Battery Pack SLB-1137 , Samsung Digimax Power Pack SLB-1137KIT , Samsung SLB-0637, 0737, 0837, 0837A, 10A, 1137, 1137C, 1137D
