The Duracell compact battery charger is a fantastic product that can fully charge your camera and camcorder battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home.
This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery. The charger is compatible with the popular camera and camcorder batteries.
- Duracell DR5700K-UK battery charger
- Product Type
- Battery charger
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- 3-year warranty
- Designed For
- Olympus LI-10B, 12B, 30B, 40B, 50B, 60B; Sanyo DB-L10, DB-L80AU
- Product Type
- Battery charger
- Designed For
- Camcorder, camera
- Localisation
- United Kingdom
- Voltage Required
- AC 230 V
- LED indicator
- Limited warranty - 3 years
- Designed For
- Olympus LI-10B, 12B, 30B, 40B, 50B, 60B , Sanyo DB-L10, DB-L80AU
