Product
Brand
Duracell Digital Camera Battery Charger
Quicklinx: 9F0JWS00 Mfr#: DR5700K-UK
The Duracell compact battery charger is a fantastic product that can fully charge your camera and camcorder battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home.
This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery. The charger is compatible with the popular camera and camcorder batteries.
Duracell DR5700K-UK - battery charger
Battery charger
United Kingdom
AC 230 V
3 years warranty
Olympus LI-10B, 12B, 30B, 40B, 50B, 60B; Sanyo DB-L10, DB-L80AU
Battery charger
United Kingdom
AC 230 V
LED indicator
Limited warranty - 3 years
Olympus LI-10B, 12B, 30B, 40B, 50B, 60B , Sanyo DB-L10, DB-L80AU
